-   -   First time using the Porta Potty (https://www.sportsmobileforum.com/forums/f9/first-time-using-the-porta-potty-19452.html)
86Scotty 05-14-2017 08:16 PM
Originally Posted by BVerhulst (Post 203081)
Does your p-trap not adequately hold water? You shouldn't be getting odor inside from your gray tank...
I agree. Something's rotten in Denmark. It is true, though, that gray water can stink as bad as black. Especially if you wash lots of nasty dishes in your rig. You shouldn't be smelling it anytime unless dumping the tanks though.
Fitz 05-14-2017 08:48 PM
Where is the vent for the grey water tank? Mine is directly below the window, most likely a typical setup when there is a window above the counter. I've noticed an odor from a full grey water tank with the window cracked open before, sure indicator that it's time to dump the tank!
https://www.sportsmobileforum.com/fo...cture34171.jpg
Glider 05-14-2017 09:56 PM
1 Attachment(s)
Happy Campers tank treatment. Works great for black tanks, grey tanks, and porta potties. :d8:
https://www.amazon.com/Happy-Campers...=happy+campers
Wowbagger 05-15-2017 05:29 AM
How well does this work relative to Rid-X RV? I've been using Rid-X since I got the rig, but the amount of perfume in it is excessive, and makes the whole rig smell of it just by what perfuses through the bottle.
86Scotty 05-15-2017 07:32 AM
I've been using Pine Sol or Fabuloso. Both are recommended by lots of full-timing seniors on boards I've read. Some don't like the smell of either but I don't consider them bad.
Glider 05-15-2017 07:59 AM
The think I like about Happy Campers is that, unlike the chemical products that many folks use, Happy Camper is not a chemical odor masker. Instead, it consists of bacteria that make pee and poo into their lunch. As a result of breaking down the organic matter naturally, the associated odors disappear because there is no longer anything in the tank that smells.
Happy Campers works great. In my experience, nothing else comes close.
