-   Hobbyist Vendor Products (https://www.sportsmobileforum.com/forums/f37/)
-   -   Swivel Seat Base GRP BUY #7 (https://www.sportsmobileforum.com/forums/f37/swivel-seat-base-grp-buy-7-a-19469.html)
EliEliO 12-30-2019 10:18 PM
Are these still an option? If so I’m in for a driver and passenger for my 2013 to 95746 please. Thanks!
wandrly 01-25-2020 07:41 PM
Did you ever figure out what the “yaw” was for?
Have the same thing and just removed it but wondering exactly what to do now. :)
Darkstar 01-25-2020 09:32 PM
I think that yaw rate sensor ties into the traction control and could cause the check engine light to come on, but there should be a way around that. I just re seated it to not take the chance..
wandrly 01-27-2020 03:11 PM
Thanks Darkstar. I posted on my other thread, but if this is what I think it is, based on some research around the web, then when it malfunctions (and possibly / probably if removed) the RSC / AdvanceTrak system goes haywire and will try and compensate for absolutely no reason when you're just driving down the road.
Doesn't sound like you've experienced that though, so a simple relocation hopefully is just fine. I did the same thing you showed on your post, with the block of wood cut out for the V plastic. Thank you for that!
Darkstar 01-27-2020 03:41 PM
Glad it helped.. I just got done putting in a Propex Propane heater ...that was a long time coming project.. always tense when you are drilling big holes in the floor... but copper line is run to propane quick connect on bumper all good!!
