-   Projects, Modifications and Known Issues (https://www.sportsmobileforum.com/forums/f19/)
-   -   Changing Aluminess deluxe cargo box door (https://www.sportsmobileforum.com/forums/f19/changing-aluminess-deluxe-cargo-box-door-24870.html)
rionapo 09-26-2019 02:49 PM
The drop-down door on my Aluminess deluxe cargo box hits the nose box on the new Chaser trailer. Aluminess will sell a side-opening door for $0250 plus shipping. :eek: Or, I could move the original door to the side, though Aluminess warns it could be jimmied from the bottom left corner since the lock remains at the top. In either event, Id have to pop the rivets on the door hinge. How hard is it to remove rivits? Install new ones if I bought an Aluminess hinge for the existing door or a new door? Thoughts on swapping the door options in general and security in particular?
Don
BroncoHauler 09-26-2019 03:06 PM
Rivets should be easy, especially aluminum rivets. Just drill them out (use a smaller drill bit than you think you need, you can always go up).
