-   -   gray water dump (https://www.sportsmobileforum.com/forums/f9/gray-water-dump-401.html)
philrod 10-24-2007 10:16 AM
gray water dump
for those of you who have a gray water tank, what have you rigged up to avoid having to lay down in order to reach the dump valve? I have a 12" hose with a valve on the end which I can reach, but it flops around a bit. I'm reluctant to have a fixed setup for fear that I might accidently break it off & damage the tank. And I don't believe I want to leave it open all the time.....
Philrod
2007 E350 V10 RB50
jage 10-24-2007 10:25 AM
I don't know what a stock van has but underneath mine has an straight pipe with a hose end and a cap on a cord, I usually leave the cap off to avoid bending and twisting.
Inside the previous owner put a bar valve right before the elbow through the floor (my gray water is under the sink). So with the cap off I can open and close the GW tank from inside the van.
kzemach 10-26-2007 01:59 PM
Oh, I like that idea. I'm gonna steal it. You got pics you can post? That might be good in the mod area...
jage 10-26-2007 02:45 PM
Pictures in the mods section. Wouldn't hurt to update this with a actual project photos...
https://www.sportsmobileforum.com/vie...hp?p=3022#3022
philrod 10-28-2007 06:00 PM
gray water dump
That inside valve is a great idea. Mine's underneath the floor. I should be able to rig up some pvc to make it easier to get to.
philrod
2007 E350 V10 RB50
