-   -   P2614 6.0 Cam Shaft position sensor open? Bad Sensor? (https://www.sportsmobileforum.com/forums/f33/p2614-6-0-cam-shaft-position-sensor-open-bad-sensor-6512.html)
khalilsc 06-21-2011 12:09 PM
My dealership is horrible and my closest mechanic is an hour long tow away :(
I had the ck engine light come on, then off then back and then I parked her. Now she cranks but won't start. Does anyone know if this sensor often goes bad? I had a engine wiring harness issue (frayed wire around a bolt) about 10k ago that I had repaired from a well trusted mechanic which was throwing the same code at the time. Any thoughts?
The parts cheap, but I thought I would get some feedback with from someone with experience? Thanks a ton!
daveb 06-21-2011 04:47 PM
Re: P2614 6.0 Cam Shaft position sensor open? Bad Sensor?
it is more of an issue with the 7.3 than the 6.0
more info here
viewtopic.php?f=39&t=5372
viewtopic.php?f=39&t=3692
viewtopic.php?f=8&t=3665
viewtopic.php?f=13&t=2871
viewtopic.php?f=13&t=2101
viewtopic.php?f=39&t=756
