-   Projects, Modifications and Known Issues (https://www.sportsmobileforum.com/forums/f19/)
-   -   Quick Aluminess install question (https://www.sportsmobileforum.com/forums/f19/quick-aluminess-install-question-8830.html)
ANZAC 09-09-2012 01:03 AM
What size drill is used to drill out the expanded bottom edge of the hinge pin?
(not the through hole itself, just the mushroomed bit at the bottom)
I need to remove and de-rust a barn door hinge, trying to be as neat as possible.
Yes, spray lube and penetrating oil didn't work.
Ford_6L_E350 09-09-2012 10:27 AM
Re: Quick Aluminess install question
I don't remember the exact size, just start with 5/16" and go up slowly. It doesn't matter if you go too large, as long as you stop before you go more than 1/4" or so into the hinge.
