Phred-SMB
Advanced Member
I have first right of refusal on a '04 F-250 Super Duty 4x4 with blown motor.
This to convert my '06 E-350 Super Duty 6.0. To 4wd.
Seller's Description:
"3,500 obo - 2004 Ford F250 4x4 6.0 Powerstroke Turbo Diesel (Not Running)
Read full post. New Bilstein shocks, 6 month old 35x12.5x17 TOYO AT II, Weld forged aluminum 17x10 wheels, new late model mirrors, newly recovered bench seat, new bestop soft bed cover, new Superchips Flashpaq F5 Tuner, leveled. Transmission shifts perfect and was just serviced with new fluids, both filters, and new shift solenoid and harness. Front and rear axles serviced with new fluid, friction modifier, and gaskets
Considering the lift on the F-250, has 35x12.5x17 tires etc would it be right to assume I'd have most of what I need to do the conversion? I do know I can pick up any and all additional needed parts but am interested to know if I can, with modification use the donor's lift, springs, t-case, running gear etc.
Would I use the front and rear axle to keep the ratios the same etc?
Would I need to swap out the transmission?
Thanks in advance for any input.
