nyyankees588
Cleaning out my electrical parts bin, description, condition and price of each item listed below. Located in Santa Cruz, CA. Local pickup ideal, shipping possible at buyer’s expense. Feel free to make an offer on any item. I’d prefer these to get put to use by somebody than take up my limited shed space. I’m happy to answer questions… but google is your friend
Keyline Iso-Pro140 Smart Battery Isolator - $115 new, asking $35
Used this in my van for the past four years before replacing it when I switched my house battery to lithium (this unit is only compatible with traditional lead acid/agm batteries). I never had any issues since I first installed it - it was fully functional when removed. I roughly cut out two exits for the wires from it and one of the backer plate screw/bolt holes is cracked (both shown in images). Neither affect its functionality.
BEP Marine On/Off Switch - $30 new, asking $10
Installed in my van for four years. Fully functional. Rated at maximum 48v, 275A continuous, 475A intermittent according to the amazon listing. Has a few scuffs, fully functional.
Victron SmartShunt 500A - $130 new, asking $100
Brand new, in box. Never ended up using it for a project. This is a bluetooth unit - it displays data via the victron bluetooth app vs. the BMV-712 that displays data on a physical display. This unit can be connected to a Cerbo GX system for physical monitoring.
Ancor 6/3 AC Wire, 6ft - ~$40 new, asking $20
Brand new, never installed/used. Left over from a project. High-quality, beefy marine wire. Great for shore power connections/main power from inverter to 120v breaker panel.
Ancor 6g black wire - $2/ft
Let me know if you’re interested in this - it’s from a 25’ spool left over from a project and I need to measure how much remains. I’m guessing that it’s around 20ft. Sells for roughly $3/ft ($75 for 25’ spool).
Fuse Block + 2x bus bars - $~30 new, asking $10
Installed in my van for four years. Fuse block rated at 32v, 100A max input. Blue Sea bus bar rated at 48v, 150A. No idea about specs for square bus bar. See photos for condition - all fully functional when removed.
