1997 Dodge Sportsmobile
greasemonkey512
New Member
new here, just purchased a 1997 dodge sportsmobile today and looking for more information or it...
Its hard to find anything online about them.
Anyone know production numbers?
Value?
here is what i know.
1997 dodge b3500
5.9 L engine, 170k miles
rebuilt trans. in 2018
cruise control, power windows, locks, mirrors, keyless entry
house a/c for shore power
tow package
2-175 watt solar panels, 2-85 amp agm house batts
2000 watt inverter
2.8kw onan generator with 30 amp shore power connection
sink with fresh and grey water tanks and water pump
dual mode refridgerator
propane 2 burner cook top with built in tank
ceiling exhaust fan
thanks, will post more pictures soon
so i hooked up to 30 amp shore power and was out testing the a/c system. The unit came on fine and was blowing cold for about 10 mins. Then it just shut it off and could not get it restarted... no tripped breakers or fuses.
I did read about a manual reset breaker 40amp maybe? a red push style but unable to locate that. does anyone have advice?
the 12v blower fan for the a/c does not come on now either.
Welcome, seems like a nice rig. Can't help with the fuse/breaker, but I'm interested in the answer. If you don't get a reply here you might try the appliance and interior or electrical forum.
found that i have two breakers and one was tripped. reset and found out the aux. condenser fan was locked up... now to find that part. any suggestions?
Thanks for the links guys. I now have working ac on both shore power and also works with just built in onan generator.
I will go to the junk yard to find a replacement fan and report my findings
I suggest pulling the seized fan motor and looking for a comparable part number online. Faster and more reliable I reckon.
1997 Dodge Factory Build Sheet
I had the same issue as a new owner of a '97 delivered with a partial Owners Manual and alot of the interior had been replaced.
If you write to Dodge and include your VIN, they will send you a factory build sheet for a '97. Great for figuring out what came from the factory, and what the Sportsmobile build added when it was new. It can't help you with that odd switch that nobody knows what it was for, though.
https://www.dodge.com/webselfservice/dodge/emailpage.html
uscustomercare@fcagroup.com
FYI- for 1998 and newer Dodge models, you can access the (Vehicle Equipment Listing (build sheet) online with your VIN
https://fcacommunity.force.com/RAM/s/equipment-listing
Few more pics
If you have not gotten the factory build sheet yet you can get one printed out at your nearest dealer.
