Ambolorian
Greetings all.
My wife and I picked up this 2002 E350 Ambulance from a hospital I worked at last year. It has 168,000 miles and they added a 4WD package.
We used it as a tow vehicle for our Airstream and now I'm in the process of converting it into a camper.
I've poured thru the threads related to this conversion but still have a few "Leader specific" wiring questions.
Here is a picture of the Power Distribution mess under the front seat. (photo from Boltline) along with the schematic that Leader sent me.
Here are my aspirations:
1. I'd like to remove the timer (C.)
2. I want the dual alternators to charge both banks of batteries (2 starter and 2 house). From what I understand in the schematic, the starter batteries are charged via the alternators and the house batteries are connected to the Emergency Solenoid and don't receive a supply from the alternators unless its activated. This solenoid is connected to a switch which lets you start the van with the house batteries if the starter batteries are dead.
Is it as easy as splicing into the alternator output and installing a battery isolator for the house batteries?
It looks like there's a splice under the passenger seat I could use (highlighted).
3. There is a Vanner inverter under the rear cabinets which I'm still learning about. Am I right in thinking that when connected to shore power its this inverter that is charging the house batteries as well as supplying 110 to the interior outlets?
View attachment 20-1050CUL.pdf
Thanks for any help with this.
Thanks for any help you can offer!
