Next step was to attach the canvas to the van. We lifted the top back up, and I laid down a layer of butyl on the roof of the van where I wanted to attach the canvas. This was easy in the back since I barely had enough room between the hole and the brake light, and the width was easy as well. I took a peak at bemerritts top to see where to position the front. once I had the butyl down I placed the rubber gasket/bulb seal. This is the same way sportsmobile does it. I then placed another layer of the sticky butyl on top of the bulbed gasket, which will seal against the canvas.
And this is where I deviated a little bit. I didn't use the wood paneling to compress the canvas onto the butyl. I just used screwed and washers and put them pretty close together. looking at my brother's, it didn't seem to do a whole lot and made it look not as nice. In hindsight I probably should have done something else and not skipped that entirely.
Same as attaching to the shell, i started on the front corner and then worked my way down one whole side. Then I attached the back corners and lastly, the front left corner. Damn that last corner was hard. the problem was that you need it to be really tight, but the drill can't go vertical because the canvas is in the way so you end up trying to put a screw through the roof at an angle which is impossible. It took many attempts... After all the corners were done I went down the opposite side and front. To attach the canvas to the roof i used varying lengths of self drilling screws (some spots needed longer ones) and washers. For the corners i used giant fender washers (2" in diameter. the screws would go through the canvas, both buytl layers , the silicone gasket, and the roof. I did a screw about every 3".
Last step for the canvas was to wrap the bungee cord around the outside, tighten it and tie it off!
