natesmithslo
**For Sale 2005 Sportsmobile**
2005 Sportsmobile with new 6.0 turbo diesel 4x4 with classic RB 50 layout
$79,000
Sadly it is time to sell
The van was converted straight from the factory at sportsmobile west(now field van) and has spent its entire life in CA.. I bought the van from the original owner and have done some extensive work and repairs to the van. The original owner provided all maintenance records as well as over $200k in receipts of work done to the van.
Since its original conversion the van has received a new 6.0 diesel motor from Ford(with approximately 2,500 miles on it. It changes as I still use the van), a new ish sportsmobile pop top with electric motor, upgraded suspension and fox 2.0 shocks, banks power pack, upgraded lithium ion battery setup with solar control and port for portable power(also set up for new permanent panels), new tires, touch up body work, both rear axles have been rebuilt, as well as other upgrades listed below.
When I originally purchased the van I took it by field van and they performed a complete inspection of the van and all systems. Any issues were addressed and fixed at that time. The van is in great shape for its age with minor cosmetic issues. Everything has been gone through and functions as it should
All maintenance has been kept up on including oil changes, fuel filters air filters, and breather filter
**Upgrades and Features:**
Classic and versatile RB50 layout with Penthouse bed is in 2 removable pieces, allowing for full standing height throughout the back of the van. Sleeps totally of 4, two up top and two on the bench/bed on the bottom
-Front and rear heat and AC, cruise control
-New Premier Pioneer stereo and true Nav
-New backup camera
-New security system and tracking
-Duel USB ports installed in dash
-Pursuit stolen vehicle recovery GPS
-Swiveling driver and passenger seats
-Custom weave floor mats throughout
-Fridge is old but runs cold
-Microwave
-sink with fresh water water tank
- Pop top tent and bed with electric motor
-Porta potty Toilet
-Electric start Furnace that runs off of propane
**Suspension and exterior**
-Sportsmobile designed Dynatrac 4x4 setup with Atlas transfer case
-Upgraded suspension with 6” lift, fox performance 2.0 shocks
-new 35” Toyo RT tires including full size spare
-17” method rims
-On board propane
-Air compressor
-Water and grey water tank
-shower and water hose in rear
-Banks power pack
-Solar plug, solar control setup
-Lithium ion batteries 200Ah plus control/converter and external solar plug and shore power
-Aluminess front bumper with warn winch
-Aluminess rear bumper with custom upgrades and reinforcement
-Aluminess ladder
- Aluminess surfboard racks(not currently on the van)
-Owl aluminum rear bumper storage box
-Fiama 10’ awning with new Z brackets included. Awning is broken and not currently installed on the van. Last i checked it was about $150 in parts to fix the awning
**Recent work**
-Van was converted over to Litium ion batters by South Swell Electical. New 200Ah Rich Solar american made battery, installed Victron DC/DC charger, victron MPPT auxiliary solar charger as well as an external solar port for portable panels. Installed new Aims Litium compatible inverter/charging unit. Van is ready for permanent panels, just plug and play. Batteries will charge while driving or via shore power ($5,200)
By Ford
-New airbag sensor
-New starter
-New alternator
-New Vacuum pump
-New hoses
-New Motor at 124, 561 miles on 4/30/22
By Tommy’s Auto Diesel Mechanic
-Rear differential rebuilt and sealed
-Both rear axles replaced
-New brakes, brake pads and resurfaced rotors
-Rear Pions replaced
-New rear driveline and u joint, all u joints greased
Will provide copies of all work and maintenance as well as the original owners manual from sportsmobile
$79,000
-New backup camera
-Microwave
-Porta potty Toilet
-17” method rims
-On board propane
-Air compressor
-Banks power pack
-Aluminess ladder
**Recent work**
By Ford
-New airbag sensor
-New starter
-New alternator
-New Vacuum pump
-New hoses
