06 Quigley w/high top for sale. Van is solid from California. Currently in West Michigan. All engine bulletproofing has been done and maintenance items at 137,000 miles. I've been planning to keep and use for a while so if it needed anything it was done. Van currently has 157,000 miles with lots of life left in it.
New tires all around
New Turbo
New brakes pads, rotors, calipers at 149,404 miles
Vacuum Pump/Brake Booster Pump
Bulletproofing
APR Head Studs
Head Dowel Set
Heads and Gaskets
EGR Kit
Blue Spring Fuel Pressure Regulator
Oil Pressure Switch
Glow Plugs and Harness
Thermostat
Fan Clutch
Alternator (High Output 250 amp)
Camshaft and gaskets
Lifter set
Rod Bearing
ABS Module
Speed Sensor
Steering Stabilizer / Wheel Alignment
Tie Rod sleeve, center link and drag link
Interior is in process of being reworked. Currently has two front bucket seats, two passenger bucket seats and a bed in back. Sorry won't have more pics for a couple weeks as it is at my cottage.
See attached pics. Looking to get around $38k.
New Turbo
Bulletproofing
APR Head Studs
Head Dowel Set
Heads and Gaskets
EGR Kit
Oil Pressure Switch
Thermostat
Fan Clutch
Lifter set
Rod Bearing
ABS Module
Speed Sensor
