2007 Ford E350 Super Duty 6.0 4x4 unique RB50 layout
El2thewood
Boise, ID
2007 Ford E350 Super Duty RB50 $78,500
Original SMB buildout in 2007 with a unique open floor plan. Eliminating the driver’s side closets for greater views and larger sleeping area. Anyone under 6’ can even sleep east/west. I have owned this van since 2020 and am the third owner. Purchased from a forum member.
Just under 92K miles. I have maintained “The one and only Ivan” (as my kids named it) for the last 5 years replacing or repairing any mechanical issues with premium, reliable parts. We travel very remote and all 4-seasons. Reliable is paramount. We all love the van and don’t want to see it go, but I have an Overland truck build and a 1973 Scout II restoration going on and the wife says I gotta list the van…
Located in Boise, ID.
Passengers: 5
Sleeps: up to 5 with larger bottom bed
37” Cooper ST Maxx tires - 2 full size spares
Deaver leaf springs and Bilstein shocks all around with airbags in the back.
head studs/gaskets and all the pertinent Bulletproof mods in 2019 Coolant filter, 7.3 fan, HPOP/Dummy pipe stuff, EGR cooler delete, FICM, etc.
Innovative Diesel tunes
4” exhaust
KC Turbos stage 1.5
The trans cooler has been upgraded Tru Cool 40,000 GVW unit
270 Amp Nations Alternator.
A Redhead steering box, pump, pressure lines, hoses 2024
Vacuum pump replaced 2024
EGR gasket, Coolant hoses, thermostat 2024
Barn door handle replaced 2025
Aluminess bumpers front (12K Warn winch) and rear. Ladder, spare tire swing out with spacer, swing out cargo box. New locking handles/latches on bumpers and swing outs
Aluminess nerf bars 5/2025
It is a manual penthouse pop top.
Pioneer Navigation deck/back up cam with Alpine Type R door speakers all around and a 12” JBL sub mounted on the kitchen counter. (I always wanted to move this off the counter)
An Edge Insight CTS2 module
In-Dash Pyrometer
Viper remote start and alarm
200w Kyocera rigid solar panel
Blue Sky solar boost 3000i
2000 watt triplite inverter
Rinorack Batwing
Hydronic ESPAR water heater and flat plate (Eberspacher)
Airtronic ESPAR diesel furnace (Eberspacher)
New interstate starter batteries with charger quick connects
Rynology 200ah deep cycle AMG house battery 2023
Starcool rear A/C
Billet Grill
New Vision 350 wheels 2024
New brakes/rotors 2024 Master Cylinder 2022
Front driveline fall of 2024
Yukon manual hubs fall of 2024
Fully protected undercarriage Skid plates Front/rear drive lines, fuel tank, batteries, Trans oil pan.
Loncoin Flooring
Penthouse insulation (reflectix) and blackout curtains
4” cooling memory foam mattress queen size
Folding SMB table, Galley Box, SMB pillows (not pictured)
Shower hook-up in rear hot/cold
Shore power with extra long cable
Microwave
Norcold fridge
16 gal. Fresh Water tank clean/flushed and ready, shurflo pump
Grey water tank
XL Underfloor Storage
Husky floor mats
Wheel bearings, ball joints, ABS sensor 2025 Axle seals 2022.
Custom rear seat cover, Carhart front seat covers and we always had all other cushions covered with blankets
Power front seat, swivel passenger
Atlas twin stick transfer case
6” lift
Sway bar disconnect
City water fill
Bushwacker flares
LED head and fog lights
High idle switch
Electronic and manual heater core coolant shutoff
In-door storage with fold down tables X3
Microwave
Dual rooftop fans
Thule roof tracks and rack
LED outdoor lights X2 (1 motion sensing)
Aimsoil filter system
Trailer brake
Original SMB folder with build sheet, schematics, owners manual, window sticker, etc. All service records during my ownership.
RV decal/number
Interior tour: View this 360° Tour
Tons of extras including a new penthouse gasket, LED front and rear lights, Renology battery monitor, SMB door stickers, extra latches, awning parts, etc.
I’m sure I’m missing somethings, so I will edit as I go through all my paperwork/records. Posting up here first
more photos
more photos
photos
We got a chance to drive this van and damn, it's a nice ride. And those 37" tires...
Good luck with the sale, somebody is going to be very lucky to drive away with Ivan!
Sweet rig! Bittersweet to see it go I'm sure but that's great pricing.
Do the Coopers run small? Those tires look more like 35's than 37's. Just curious as I have thought about going up in size, but I think I may need to do some trimming.
Good luck with the sale!
I have never thought they were small or run small. I had to change one on the side of the interstate years ago and I really wished they ran small then…
Great looking rig. I’m looking for a 4x4 SMB van to bring up to Alaska for both summer and winter fun. Since it’s best stored in my garage during the winter can you let me know the exterior height to the highest point of the roof without the crossbars and solar panels (if they can be removed during the dark winters in AK).
Much appreciated.
8’ 2.5” to the top of the rooftop fans. Which is nearly the same height as the solar panel (easily removed T-nuts) and 8’5” to the roof rack (also T-nuts).
Thanks for taking the measurements. Much appreciated. That’s makes the header of my garage a few inches short. I’ll find out how much easing the header and a new door will cost me. Ivan would do great in Alaska.
You probably thought of this, but this rig has 37" tires and probably a 6" lift to fit tires that big. That, or a ton of fender trimming.
By comparison, I can fit my SMB in the garage with a 9' header. 3.5-4" lift with 35's and inches to spare on the penthouse with a low-profile rack and solar panel.
True I thought about that but it’s a bummer for ground clearance. Do you how much work it would be to lower the lift? I’m sure I could sell the 37s in AK for a premium…
Yes on the 6” lift. It’s listed in there, but maybe I should reorganize my listing into better groupings for ease of reading. I’ll work on that. I’ll be posting/listing this to the masses this week.
