2009 Ford E-350 4x4 SPORTSMOBILE, EB 43 (extended body) 6.0 L Diesel Engine
woodbee-SMB
Rohnert Park, CA
FOR SALE
2009 Ford E-350 4x4 SPORTSMOBILE, EB 43 (extended body) 6.0 L Diesel Engine (New Starting Batteries Installed, 10/29/2024)
5 Speed Automatic Transmission, GVWR 9,500 lbs.
Well taken care of, very good condition
Located in Rohnert Park California
$77,000
Or
Make an offer
All reasonable offers will be considered
I could only add 10 pictures, if you would like more, please ask or check-out my albums on sportsmobileforum.com, my handle is “Woodbee”​
First and only owner.
Clean Title
Miles on the speedometer as of October 31, 57,135 miles.
I will except only Bank Issued Cashier’s Check as payment, and the buyer is willing to meet with me at B & C Registration in Rohnert Park CA to finalize the paperwork.
Please, Serious Buyers only.
I will not except offers from Brokers or any trading.
OTHER INFORMATION
When the buyer agrees to purchase our van, I will need to have a SMOG inspection preformed for the sale.
At one time we had a Satellite dish on the roof of the Penthouse Top, I removed it and filled all the screw holes with Silicone Calking and Stainless Screws.
I preformed all maintenance on the things that I could and took it to Ford on the things I couldn’t do.
2014, 29,290 mi. Oil Cooler replaced by Ford in, Salina Kansas
2015 new Lifeline GPL-4DL Deep Cycle AGM Battery
One, 220 watt Solar Panel (installed by seller)
2016, 38,847 mi. Resealed Bedplate, replaced rear main and front crank seals
replaced front and rear cover seals, Ford in, Petaluma, California
2023, 54,802 mi. NITTO LT285/75R17 Ridge Grappler Tires
2024 Oct 29, 57,127mi. 2 new BXT 65 750 Starting Batteries, Hansel Ford, Santa Rosa, CA
THE BUILD
I have the original build sheets
Conversion by, SPORTSMOBILE West, Fresno, CA
EB 43 floor plan
Penthouse Expandable Top
Zippered Screens (front and front 2 sides)
6 Cabinets
1 Sliding Pantry
LONCOIN Flooring
Day/Night Shades
Leather Seats and Gaucho
Solid Surface Counter Top
16 Gallon Water Tank
4E NORCOLD Electric (12 and 110 volts) Refrigerator
Flush Mount 2 Burner Stove, propane
Propane Furnace 12,000 BTU (12 and 110 volt)
Marine Toilet, Fresh Water Flush with Black Water Holding Tank
Water Heater, 6 gallon, propane
2 Frame Mounted Starting Batteries
One Large House Battery 40 AGM
Electric Converter 110 volt-12volt
19” Flat Screen TV with DVD Player
XL Storage Compartment, under floor
Captain Seats with Adjustable Lumbar
Awning, 7’ 6” x 10’
Trailer Receiver Hitch, class III, 10,000 lb.
Removable Bed, sleeps 2
AXEL RATIOS, 4.10 with limited slip
46 Gallon Fuel Tank
ATLAS II Transfer Case
Dynatrac Pro Rock 60 Front Axle
Track Right Wheel Spacers
Old Man Emu Shocks
Sportsmoblie West’s Larger Brake Rotors
HELLA Remote Tire Monitoring System
Custom 17” Wheels
DYNALOC Hubs
TROJAN “Front Bumper, with grill guard
TROJAN “Rear” Bumper, with Swing-out Tire Carrier & storage Box
TROJAN Expedition Kit (axe, shovel & brackets)
HELLA 500 Fog/Driving Lights, pair
PICADOR Utility/Backup Lights, pair
Nerf Boards
Thule Track Mount Rack W/72” tracks
WARN WINCH 12,000 lb. with Roller Cover
BUSH WACKER Fender Flares
GORILLA Wheel Locks
AMSOIL Dual Filter Kit
Dual Alternators
Backup Camera
Message Center
California Emission System
ITEMS TO GO WITH THE SPORTSMOBILE
Motorcraft, FD-4606 upper and lower fuel filters
1-Motorcraft, JK8-1311 Serpentine Drive Belt
1-Motorcraft, JK8-1375 Serpentine Drive Belt
EXTREME OUTBACK, portable hi-output air compressor
Extra air hose w/gauge to fill 2 tires at a time
HI-LIFT, “Lift-Mate” LM-100
BLACK RAT, Mark II 4WD Heavy Duty Off Road Block, 8000kg
Tire tools to brake down a tire
Tire bead breaker
Tire repair kit
2 pop out road cones
Spikes to tie down awning
Gray water drain hose
Black water things
Black & Decker P1500BB 500W Power Inverter​
New posts
