99 EB-50 Rebuild in Palm Springs CA
It does really look great. Patience test.
re awning- yeah - bag awnings are closer to 8 - 10 mins minimum with two people, provided you have the 6 feet clear to extend it, and good conditions. And then remember your bag awning is about 7ft off the ground. They are a pita on a 4x4 van, but people need to go on their own path to discovery.
Re: heater - mount the "crappy" tank and get the heater working for ski season. We ski three to four months straight out of our van every day/night. Our heater is essential. Get the heater operational now and you can solve the tapping the fuel tank issue later.
As I mentioned before, the rear TF tank level is always matching the front tank level, neither is higher than the other, nor does the rear tank run out of fuel first. Tap which ever tank is easier and run your pick up tube to 1/4" or so of the bottom of the tank.
A good place to mount the "temporary" tank is on back side of your bumper box between the box and the door. Easy to fill and easy to route your fuel line. Plus you can run kerosene vs diesel which the heaters like a bit better.
Thanks Ray. I think you're right about just fitting the tank and dealing with the proper hookup later.
Regarding he awning, I was actually just considering carrying a simple flysheet onboard (specifically, inside the second barn door where the clunky box / table thing used to be). I have a little plan and I'm going to see how I get on with it.
This may all culminate in my fitting another Fiamma, but probably not.
Okay so it took me what, 10 minutes solo setting my bag awning up the first time not knowing what I was doing. It can be done. yes it is a pain in the arse, but in my case needed to be done to reduce stowage usage IN the van and it does go up easier than a tarp / flysheet by a LONG SHOT... Either way you are basically wresting with a wet noodle...
I replaced a 10x10 tarp with suction cup mounts and old school Coleman Telescoping tent poles with the awning. I have no regrets yet, but I tend to be stubborn so there is that.
You can as Ray said mount the "crappy" tank to the back door outside of the van however you have availablee, and just call it good for now. Depending on the size of your crappy tank and how warm you like it you will likely have to refuel the heater every 3 - 7 days. I do have a diesel heater as well, 15L tank model and on low using it for my pickup truck shell camper it gets me a week of cooking me out of the camper before I have to get more diesel, by then I am back home anyway...
OK, the refit is pretty much complete. I still need to make the magazine holder cubby thing in the rear corner, the kitchen drawer, and add some T molding to a couple of my doors, because I ran out. Plumbing also needs a little bit of rework because the two tanks don’t cooperate very well when being filled. I think it’s a venting problem, hopefully a straightforward fix.
I haven’t taken a final picture yet, but here is a random selection of shots to show how things went.
Overall, I’m very happy with the end result. My favorite changes were the sound insulation in the cab, the tweed fabric I used throughout, which I love, and going from heavy three-quarter inch MDF to much lighter half inch prefinished ply on the cabinetry.
The added benefit of getting some weight out of this thing is that it now sits level. Before, it has a slight sag in the rear, and I really didn’t like it.
Between this, the sound insulation, and the suspension changes I made right after purchase, it feels like a totally different vehicle. I loved it before, and was willing to forgive its quirks, but now it just feels top quality, and really just fantastic. Happy.
Getting rid of that stupid pullout pantry thing was a good move. Can fit probably twice as much food in there!
Under-seat lighting was a great suggestion from earlier in this thread. It has the added benefit that I can see all the electric and plumbing when I lift the seat base up, which makes things a lot easier to work on.
Sorry doublevan, I’m doing this from my phone and didn’t want to lose the post!
I’m on my way to go skiing in it now. I will continue posting updates as I finish off the last few items. I’d also like to get all the window tints replaced. They are looking very old now, and I like the idea of the solar reflective stuff that is available now.
OK, here’s my solution for the diesel heater tank situation I was up against. I really really wanted to be able to draw from the auxiliary on-board fuel tank, and not have some plastic box sitting on the back of the van.
I made this using odds and ends that I had from previous projects, so it’s not the most elegant solution, but it will do for the time being.
This is a 1.5 inch hose connector. I drilled a hole in the middle, and glued a push fit quarter inch pipe fitting into it using T88 epoxy.
I carefully drilled the step on the back of the push fit fitting so that the pipe would slide all the way through.
I then added another push fit fitting to the end of the pipe so that it had some mass and would want to sit in the bottom of the tank. My initial tests had it curl up where it was unable to draw fuel.
It seems to work great. I may remake it with better quality parts at some point (maybe once that epoxy joint fails! I’m totally going to **** for that bodgery).
That was a huge undertaking that you banged out in impressive time. Beautiful work! I'm sure you learned a ton and hopefully had some fun doing it. You gave that rig a whole new life. Kudos jam
Thank you bigriver. I bought it to use it, and really didn’t like having it broken and off the road.
I absolutely bust ass on it, especially in the last few weeks. Lots of 16 hour days with 2am finishes. I wasn’t sure at the time, but it feels worth it now.
Your van looks great. Really like the materials and the look.
Yup I've learned the hard way.. don't take things apart and leave them apart! In the aviation world we call it "AOG" (Aircraft On Ground) and it's a no-no. An airplane that can't be flown because of maintenance issues is useless. Same with our campers..
Very nice job on your van.:d5:
Thank you. Yep, I feel exactly the same way about this van as I do my RV-6. I don’t mind little things that need attention here and there, but AOG is both stressful and a difficult situation to extract yourself from when it happens.
ctW5Rv0
OK, figured I'd wrap this thread up. I got the rebuild 95% done before we headed away on our Idaho-Montana-Utah ski trip and my work to that point held up well.
I finished the last few items once we were back, concluding a few days ago with the little cupboard thing that lives in the rear right corner.
Here are some details of the van - what I like and don't like.
Here's a shot of the interior completed. The utensil drawer under the sink goes all the way back to the side of the van, with much higher sides than the original. This probably doubled the capacity and it's -awesome-
Same with the pantry. I did away with the stupid slide-out thing and put the lower shelf down as far as it would go. Also probably double the capacity over the original. It's also just simpler to use.
I reused a few bits of original SMB hardware, including the lighting, which I liked, and the stainless heat guards over the cooker. I also kept the Norcold fridge, which was working fine.
I tried some brushed metal-effect wrap on the fridge, but it looks like crap and is attracts dirt. It's very easy to change (undo a few screws and slide the panel out) so I'm going to change this out to pre-finished ply to match the rest of the interior.
Here's the solar controller. I have three panels up top and am only using two because the third one is old and different voltage. The controller doesn't like that. Previous setup had two solar controllers which Renogy advised would probably be fighting each other. This was an installation done by a 'professional' van outfitter, ugh.
I did-away with the gigantic inverter and microwave, but kept the two big 12v lithium batteries. This saved a lot of weight and so far I haven't missed the microwave.
I love this panel. The top gauge shows the state of charge and rate of discharge, and the lower three switches are L-R under-seat lighting, water pump and master on/off.
The under-seat lighting was suggested by someone on here and is really nice. I used LED tape, glued to the frame of the seat.
As I mentioned, I used most of the original SMB lighting. The USB charge port to the right has a tiny blue LED which illuminated the sink very very slightly, making it easy to deal with at night. It's not enough light that you can see it when you're in bed.
I went with a second tank to give me a lot of water (the inverter used to live where the smaller tank is). Left side on the front panel is a 12v socket for my boy's iPad when we're driving, and a hardwired CO/propane detector. Diesel heater lives in the left rear and is ducted to the front of this panel between the lithium batteries and big tank. I like to think this helped keep the water from freezing and batteries from being stone cold whilst we were at arctic temps in Montana, but who knows?
CRL window was worth it. I wish there was an option to replace the sliding kitchen window on the other side.
Switch panel to control the exterior area lighting.
Headliner. Light is from a BMW in the salvage yard. Visors were trimmed by my local shop. He's a young dude who was taught by his dad. The dad unfortunately died, but he took over and does -beautiful- work. Will give him my money all day long.
USB sockets where the CB radio used to be. These pods are from Amazon and can be ordered in different configurations. The USB on left used to have a blue LED which was really bright at night. I put a tiny screwdriver through the hole on each of them and managed to get them to go away.
I like this bit. The bin is really really handy in this position. Beforehand we didnt' have a bin and had to use a plastic bag or whatever. Total game-changer.
This is me making the last piece of the jigsaw puzzle. Was kind of out of practice when I did this - the edge bead being a bit wobbly. It was not noticeable once installed.
Here's the rear box thing installed (out of focus to right of image) I took this picture because I'd like to try to find a third reading lamps for back of the van (where the two wires are hanging down) - I like the light they give out and it would look cool if they all matched.
So that's about it. Massive undertaking, not sure if it was really that fun but the end result is satifying. Having the ski vacation deadline made it quite stressful towards the end and I'm not sure I got a chance to stop and enjoy any of the progress.
Last weekend I pulled the van out to take my boy to King of the Hammers. I climbed in through the barn doors and was struck by how nice it felt - kind of like a yacht, or maybe a Sprinter built by an outfitter.
We had a great couple of nights camping, did some fairly hefty off-roading up around the hills, and got to watch our friend win the Unlimited class. Money-cant-buy kinda situation and a nice affirmation of why I got this thing in the first place.
Here's my last shot - it was our first night on the ski trip - just me and my brother in the mountains in Idaho (my wife and boy were flying up to meet us the next day). Diesel heater on, absolute solitude, stars, and that crazy damped acoustic that exists only when you're surrounded by deep snow.
Was this whole thing worth it?
Worth it.
:e5: Well, sometimes crap :b1: leads to a beautiful and extremely satisfying outcome. You did a stellar build.:b5: Enjoy it !!
Hands down one of the best interior buildouts I've ever come across. Looks clean, neat, clutter-free, professionally done. Beautiful job!
I know everyone likes the stainless steel, but I agree.. I think the matching wood fronts look better.
No doubt - they are usually way too bright. What I've done a few times is find the positive terminal to the LED and solder on a resistor (75-100k). That can change the light from blinding bright to a soft glow.
Enjoy your new van!
