evy
Passenger air bag connector must have been stretched by the passenger swivel seat, the airbag light stays on.
I've tried everything, wiggle it, clean it, added dielectrique grease, etc... nothing seamed to work so I cut the connector off and connected the 2 wires directly.
I did all of this with the negative wire on the battery disconnected (over 15min) and the airbag light stays on.
I have a basic OBD2 scanner that reads a B1213(13) code that seams to be linked to the airbag light and the seatbelt buckle pretensioner.
I don't have a lot of experience in automobile fixin so I'm not very comfortable with deleting codes on my OBD2 scanner, I'm afraid of messing up the ECU.
I read that when you fix the problem you have to go to a dealer to clear the code, can anyone confirm?
Can it be a simple dirty Seatbelt buckle?
Thanks for any help!
(Ford E250 2010 V8 5.4L)
