Big B
New Member
Hi, I have a 2006 ford e-350 6.8l v10. My catalytic converter was stolen and I am having trouble figuring out the correct one to order. Or even a straight pipe to order.
The stock on the 6.8l doesn't fit with the Quigley conversion. Drive shaft and gear box get in the way.
Any suggestions? Thanks!
Did you try calling Quigley?
QUIGLEY MOTOR
COMPANY, INC.
100 Sunset Drive
Manchester, PA 17345
(800) 233-9358
Why not just take it to your local muffler shop? Cheaper and simpler. There's nothing special about the exhaust except it's been rerouted.
I do suggest you take Marret's advice and get a Quigley parts list from them from your van if you don't already have it. Call them and ask for Kevin Wilcox.
:b5:
Depending where you are your options are limited at best. In CA, Magnaflow PN 4451300 is the only approved cat that can pass the BAR smog inspection. That PN is a universal unit but they have a direct fit one that will pass as well.
Scott
Big B -- be sure to let us know when/where you find a supplier for your CAT and maybe how much it set you back in $$ -
Your 2006 came with only one cat?? My 2007 has four!
Wow! Didn't realize there was such a variation in how many cats an Econoline might have. Mine has two smaller cats on each exhaust header for a total of 4.
One reason I bought the 1992 7.3 IDI in my driveway... pretty much no emissions controls at all (it probably has an EGR and basic EVAP, but that's about it).
The irony there being I have a desire to put cats in most/all of my classic cars. :b1:
