Cigarette Lighter Socket Cover
Youngster
North of SanDiego
Well, I spent a half hour searching this forum and Google looking for a replacement cover (mine is missing) to the cigarette lighter / 12v port in my van's dash. No luck.
Does anyone know of a source to get a replacement cover flap?
I don't even know 'exactly' what this part is called. If someone has a part number or correct name for the part that will help with my searching.
It's just a little thing but I'm apprehensive about my toddler sticking his fingers and other things (metal) in there since it's exposed.
2003 E350
I have no idea where to find one, but it sounds like a great excuse for an excursion to the wrecking yard.
I'm pretty sure you'll need to replace the section of dash trim where the power port plugs are located. Your year should be a hinged cover, I have two E-Series vans with those same covers. Given the age of that trim you could have a tough time finding a replacement in good condition that doesn't have issues with the hinged cover.
I've found several on eBay in various conditions, none so far good enough to suit me. Here's an example: https://www.ebay.com/itm/97-02-FORD-F150-ECONOLINE-CUSTOM-RADIO-AC-CONTROL-BEZEL-USED-OEM-BLACK/391778340823?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 There is some damage but its mostly hidden by another trim part so not a huge deal. The attachment clips pretty much assure the part would be secure to the larger dash panel.
You would want to ask the seller if the hinged cover works properly---sometimes that's not a high priority to mention on eBay.
For my money I'd go with the easier after market replacement plug shown above. Cheap, easy and not at all unappealing and adding in the affected plug is a bit recessed in the trim panel it's not easily removed by young curious fingers.
HTH
Pick apart. That is where I got mine And it fits in your pocket so it is free.
What's worse is when your toddler jams the Chinese accessory plug in so hard it shorts the fuse, and then does it again and again until you're out of ports until you play find the fuse. I have four ports in the front and only the one in the headliner is ever not blown.
I keep a USB adapter plugged into mine, not pushed all the way in until I actually use it since the jack is hot all the time.
Get this:
https://www.amazon.com/Blue-Sea-Systems-1015-Socket/dp/B076GZQN98
After my power port hinge door broke off, I replaced the stock socket with this Blue Sea 1015 Socket. The Blue Sea unit has a higher charge voltage and is a bit deeper (which helps to keep my cb radio plug from falling out.) The Blue Sea rectangle cover pretty much covers the ugly rectangle void left behind.
I replaced the second power port below it with this Blue Sea Dual USB charger. It's trick.
https://www.amazon.com/Blue-Sea-Systems-Charge-Charger/dp/B01BV1MTAA/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1536633178&sr=1-1&keywords=blue%2Bsea%2Bdual%2Busb&th=1
