geoffff
For years I've been trying to track down this annoyingly loud "clangity-clang-clang" sound from under the van that happens whenever I drive over a series of bumps (which is anytime I'm trying to have "fun" with the van). This kind of problem is so hard to find when parked in the garage. I've been tempted to somehow hang upside down looking under the van as my wife drives.
Anyway, I've been spending a lot of time lately in the garage crawling around under my van, and -- I think I found it!
The left(driver)-rear shock is positioned only a few mm from my TransferFlow gas tank, and the shock appears to have been banging against it. A lot. See photo. And sure enough, if I tap on this with a wrench, it makes the same kind of sound I've been hearing while driving.
If you happen to also have a Ford regular-body with the TransferFlow gas tank, you might want to take a look into this as well.
I'm not sure how I'm going to fix this, as I don't think I can move the tank or the shock. I will probably try to find something strong and thin and impact-absorbing to wedge in that crack.
Any ideas?
-- Geoff
Any ideas?
-- Geoff
