carringb
j.whitbread said:You can buy a lot of gas for $20,000. That said, you could find a used (Ford) Cummins engine with the matched Ford transmission out of a F650 or similar to swap at a junkyard for much less than $20k.
The Cummins is only paired with the Allison 5 or 5 speed, or with one of the Eaton or Spicer transmissions (inc. Eaton auto-shift). It is not currently available with a Ford transmissions. I'm not sure if it was in the past. I don't think any of the F650 transmissions would fit well under a van. They are all huge compared to the van/pickup transmissions.
