Does anyone know if the rear wheel bearing hubs on the full floating Dana 70's were all the same for the E350 dually van chassis axles? I looked up a 2004 on ford parts and it shows discontinued. Then i look up a 2005 with dually and it lists the part. Is the 2004 and 2005 part the same?
I need to order a new dually hub to take to my machinist so he can make measurements to build me a set of custom bearing hubs with the 8x200mm lug pattern and a larger diameter hubcentric shoulder.
The plan is to use 7000 series aluminum to machine complete new bearing hubs. I had a company lined up to make them over a year ago but then i got bad sick and put everything on hold and now he is way to busy to do one off custom work so i found a different machine shop that is going to do the work.
I know alot of people are running aluminum wheel adapters/spacers. Wheel adapters says the thinnest he can make adapters is 2 inches. That would push my tires way out beyond my quarter panels and look terrible. Then i would be constantly worrying about a wheel falling off.
My rig weighs 10,400 pounds dry. Do you guys think what im doing is practical using high grade aluminum or should i have them use steel?
