I purchased a Vevor 2.5kw diesel heater. I'd like to mount the tank outside the van so I don't have to worry about fumes or the tank spilling in the interior of the van in the event of an accident (or worse).
I was originally thinking I could mount the plastic tank on a frame rail and add an access hole on the side of the van for easy fill ups at the gas station.
The 10L tank that came with the Vevor heater is pretty big and would not fit on the frame rail. I could probably find a smaller tank, but getting easy access to fill up the tank might prove difficult. I guess I could add a filler hose, but I'm not seeing good options there as well. Obviously the more DIY things are, the more potential for leaks. So ideally looking for somewhat of an off the shelf solution.
I'm wondering what others with similar set-ups have done. Thanks!
