Double pictures to be erased, please. Solved, thanks
Re: Double pictures to be erased, please.
There's also a small X in the bottom right of each picture. Click that to delete the picture. Now, does anyone know how to delete a comment made on a discussion stream? I've occasionally made comments I wish I hadn't.
I still get this when I click on Delete:
"You are not authorised to access this area."
Hmmmm! I get the same message. Okay, Jage, what's the trick to deleting pictures?
This worked for me:
Click on My Gallery
Click on Moderator Control Panel (Right next to Edit this Album on Upper Rightish)
Find Pic or Pics you want to delete and Mark em.
Then on Bottom, Find "Select Desired Action"
Select "Delete Image"
Mac,
You can go into any post you have made and edit it. Click 'edit' in the upper right corner of the post and delete or change whatever. You will notice the little 'edit' button only exists on your posts, you can't edit someone else's post.
NRL said:
This worked for me:
Click on My Gallery
I just tried this after I noticed some of my pics are duplicated 2 or 3 times. It acted like it worked, but the pics are still there. What now?
Ford_6L_E350 said:
I believe pictures are locked to prevent deleting photos that are in a posting. Once an embedded picture is deleted the post can become nonsense.
thanks Mike, so I guess they are stuck there? I think it happened when my computer kept timing out from trying to upload several at once, so I hit resend thinking none of them went through. Apparently they did.
86Scotty said:
That has happened to me several times. I've learned to look in the gallery first after it has timed out to see if the pictures are there before downloading them again. It now keeps me from doubling up the pictures.
