Facebook marketplace finds
That extended wheelchair van is a perfect candidate for a motorcycle hauler with the tall rear doors and rear lift!
I thought the same thing about this one (priced at $13k):
“For sale is a clean 2005 Ford E-Series E 350 SD XLT 3dr Extended Passenger High Top Van With ORIGINAL LOW 36K Miles. 6.8L V10 Automatic Transmission Handicap Ramp Lift Power with Manual release function Front and rear separate A/C & Heat This vehicle is in good working condition. Very clean inside and outside, A/C and heat works good. Clean PA title.”
https://www.facebook.com/marketplace/item/479116361426423/?mibextid=HHaHfI
title status: clean
transmission: automatic
type: van
2003 FORD E-250 5.4L 2WD TUSCANY BRAUN HANDICAP VAN
CLEAN TITLE
VIN # 1FDPE24L03HA96021
118k Miles
POWER: Steering / Brakes / Windows / Cruise Control / *(OEM FORD) Drivers Seat
NEW PARTS:
BRAKES FRONT AND REAR OEM FORD SUPER DUTY PADS & ROTORS $1,200
STEERING LINKAGE & BALL JOINTS *(FRESH ALIGNMENT) $2,200
BFG 285s $1,350
RACELINE AVENGERS $1200
BILSTEIN HD SHOCKS $900
UPGRADED HEADLIGHT HOUSINGS & BULBS $ 120
FRONT & REAR A/C *(REAR has its own unit. Spent $$$ on making it bulletproof)
Handicap Features:
BRAUN VANGATER II WHEELCHAIR LIFT w POWER DOOR OPENERS *(Wireless)
BRAUN 6 WAY POWER SEAT BASE
PASSENGER SEAT HAS QUICK RELEASE BASE (For wheelchair user to sit passenger)
FIBERINE 16 INCH AERODYNAMIC RAISED TOP (With Raised Doorway / Modified Door Tops)
CUSTOM 6 INCH DROP FLOOR WITH WHEELCHAIR L-TRACK & TIE DOWN MOUNTS
MPS HAND CONTROLS
Upgrades:
JVC BLUETOOTH / DVD / CD / RADIO / BACK-UP CAMERA: 6 SPEAKERS
POWER FULL SIZE BED raise head and/or feet: with 4 INCH MEMORY FOAM MATTRESS
PULL DOWN WINDOW BLINDS w SLIDING BUG SCREENS
MISC UPPER AREA STORAGE
TV *(with Digital Tuner for Local Stns) / DVD / VCR with Remote Control
VAN IS UNDER 9 FEET TALL!
***FITS THROUGH MOST DRIVE-THRUS***
This is a Tuscany Creative Mobility RV Handicap Conversion Van. The cost of this build new was $64,000.
$11,000.00
Call or Txt Stewart 818-seven three zero - 9490
Added the specs/text from each for sale listings for posterity -- eventually FB will delete ads and if you only post the link (without photo(s) and the listing text), it will be a dead link lingering on the forum for years to come.
Specs and photo:
2008 E350 econoline Van
6.0 power stroke diesel
224,000 miles
4x4 conversion by Quigley done when the van was new
Not fully bulletproofed(head studs not done but upgrades EGR cooler, injectors)
New HPOP
New fox 2.0 shocks
New power steering pump
All new steering gear
New batteries
2 solar panels
100ah house battery
Max air fan
No leaks
2003 7.3 diesel extended 350 u joint , Quigly , 4 wheel disc 1 ton suspension, 37” Yokohama tires , runs mint 143000 miles 40k$
You always said: "If it only had a V10..."
Well now it does:
2006 E-350 6.8L V10 Chateau Wagon, 149K miles $ 15,450 Centre, Alabama (Northeast AL just across the line from Rome, Georgia). Luckily for me and my wife, I already have a '95 Chateau Van, otherwise I'd be looking pretty seriously at this one.
https://www.facebook.com/share/1EvoR9GMbs/
