Fresair S6 - AIR COOLER - Van Conversion Kit
AbsoluteFreedom
Advanced Member
Ca
$1250 Brand New (in the box)
(Cost was $1700 after tax and shipping)
It was painted to match my van, but decided to go with an undermount AC unit.
For Van Conversions, RVs, Stepvans, Trailers, etc.
Energy Efficient + Runs on 12v using <8A/h at full power.
Light Weight – 25lbs
Low Profile – Streamlined, 3.7″.
Includes your choice of 18L Reservoir or Mini Reservoir with universal mounting capability.
Adjustable Ceiling Vents – 4 directional vents.
Powerful Cooling – Up to 40° drop in air temperature.
Eco-Friendly – Runs on tap water.
Low noise – No compressor or engine noise.
Runs Dry – State of the art evaporative cooling technology delivers cool air, not moisture.
Retrofit – Can be used in preexisting 14 x 14 opening
Powerful Cooling
Temperature drop between ambient temperature and vents can reach -40°F! On average at 85°F ambient temperature, you will see a 20°F+ drop. The hotter the environment the larger the drop.
Energy Efficient
Fresair runs <8A/h at full power (tests read approx 7A/h) which is only slightly more than a simple roof fan. Compared to traditional rooftop AC units you’ll be using approximately 20x less power.
Eco-Friendly
Running on water and battery power alone as well triple-filtering the air and running clean, even off solar power alone, Fresair is your green energy solution.
Easy Maintenance
With only needing to replace two pumps (injection & return) and a pine filter approximately once a year, the Fresair is low maintenance.
Check out https://fresair.com/units/s6-van-conversion-kit/
714 376 2562
