IceKing
New Member
Howdy everyone. I have had my van for about a year now and I love it. 2006 E250 5.2L that I use as a tow rig for my track car and a weekend camper. It is currently giving me a headache with the tail lights. Recently I noticed that my tail lights were out on my way back from the track. Turn signals and brake lights work fine, but the tail lights were not functioning. I am having a **** of a time figuring it out. I feel like I have to re-learn wiring stuff every time it comes up, seems to never stick.
Details:
- I installed a tow wiring kit which is a 4 pin harness that then connects to a 7 pin. The 7 pin is wired to a brake controller. All from E-Trailer
- When I plug the 4 pin into the 7 pin, fuse 10 pops immediately. Seems like the culprit but the fuse has popped when the 7 pin is isolated from it.
- I used the 4 pin to the trailer bypassing the 7 pin and it popped before I was out of the lot.
- The fuse does not pop immediately when the 7 pin is disconnected. How long it takes to pop varies.
- The right pig tail had a loose-ish brown wire that when jiggled it cause the light to flicker.
Attempts So Far:
- Replaced tail light bulbs, third brake light bulbs, license plate bulb.
- Replaced the right pig tail with a new one.
- Multimeter used to confirm 12 volts are getting to the factory pigtail. Red probe on brown pin, black probe on black pin. 13.5 volts present.
- Same with the orange wire for the turn signals. 13 volts present.
- Tried a 30 amp fuse, no luck.
-There are no continuity/voltage problems with the 4 pin harness.
- There are no continuity problems with the 4 pin wiring that is in the 7 pin plug.
- I unwrapped a few sections of the factory harness but found nothing strange. Have not unwrapped it all yet.
Something I find odd.
With bulbs removed, and third brake light unplugged, I get continuity from all three wires of the pig tail with a bare metal patch of the body. I thought that would only happen with the ground wire. This leads me to believe there is a few bare wires touching the body.
I would really like to get this resolved before I start to figure out installing walls and especially before my next track day. Any ideas will be immensely appreciated.
Details:
Attempts So Far:
