I very much doubt Velit's heater is made in the USA. I have installed the made in China heaters and have found them very reliable if purchased from a reliable vendor. Velit may be doing additional inspection and testing on their brand units.
You may very well be correct. I don't see it listed on the web site. Others have shown them with made in USA stickers on them. However I see they claim engineered in USA, manufactured in China. If you are familiar with made in China, the biggest issue is quality control (or lack thereof) that is dependent upon the particular brand...
2kW vs 4kW - . Espar diesel 4kW is what we have for our EB Pop Top. Nice is it runs on low most of the time after bringing the cabin to temp. Bad is because it is so much heat it can short cycle leading to fouling of the atomizer screen. I make it a point to run it at max temp for about 5 to 10 mins before shutdown for travel. 2kW will run in medium more often and typically has less fouling especially with gasoline versions.
My main usage for this is to travel to where the snow is. I have lived in coastal TX basically my entire adult life... I figure in deep snow I will need heat to keep from freezing to death especially if I pop up the Penthouse roof... And I would rather have the capacity and not need it. I do agree however, even if I was going with a Diesel, run it on high for a bit before shutting down to keep it running clean.
Some tips -
1. Mount the heater in a place where it is easy to get to for servicing and where it gets good air draw.
2. Outlet for heated cabin air goes as close to the floor as possible - heat rises
3. Thermostat/control gets mounted about 30" above the floor, away from the heater outlet and well below the bed platform - heat rises
4. Exhaust outlet under the van - take into consideration that it may snow a couple of feet while you are sleeping. Think about where the exhaust will be in terms of shutting down due to snow accumulation as well as CO concentrations under a rig with snow above the rocker panels.
5. Buy a couple of spare atomizer screens and tool set, that is what will need replacing at the most inconvenient moment.
6. A 12v fan or two will help move the warm air all around the cabin for a nice even temp from to back and most importantly up top when sleeping. Much hot air will be trapped under the bed platform.
Cabin heat from these types of heaters is really nice!!!
1, 2, and 4 are very related. I plan on mounting in the drivers side in the dinette base. Snow accumulation IS a concern, and may cause me to go to the passenger side so that exhaust can be run under the awning keeping snow drifts from clogging it up... I was hoping to route the heat from the heater through the drivers side dinette base as that is where the Lifepo4 batteries will be mounted. I figure the heater can keep the batteries above the freezing point...
For point 3, I plan on putting the controller / thermostat next to where Sportsmobile mounted the Thermostat for the Starcool. So about 32" off the floor just about midway through the "house" section of the van...
For point 5, a VERY good piece of advice, thank you!
For point 6 I am installing 12v to USB charging / power ports throughout the van and replacing the original lamps with fans and LED lights as both of those will use less power than just a single incandescent bulb... My main lighting in the house will be LED light strips along each side of the bottom of the, not sure what you would call it, original van roof next to the openings for the Penthouse roof... Super low power use, lots of light, and I can do different colored lights depending on my mood... Like green and red color shifting for Christmas etc... Yeah I know dumb, but effective...
The big thing is I want to avoid having to have too many different fuel types, and gasoline heaters tend toward stupid expensive... The Velit SEEMS to have decent reviews / reliability. And FWIW I was originally going to go with a Vevor 5KW 15 Liter tank diesel heater. I just figure with gasoline I can tap my van fuel tank and have heat when I want it... Mostly to keep from freezing while I am sleeping...
I am not necessarily wedded to the idea of the Velit and if there are other quality and budget friendly gasoline heaters out there, I am all ears. So far I have found the Velit at $649.00, the Espar units that seem to run the range of $1799.00 to $2999.00 and the Webasto Air Top Evo 40 at $1549.00. The difference in price between the Velit and the Webasto is right at $900.00! That is not as much as it used to be, but still That is a nice fridge AND stereo head unit kind of money...
