Hello: 2004 SMB converting gas to diesel
Following, just found out yesterday I will need a new V10 in my 2006. Looking at options. Are there options for a 2006?
Several posts lately about people needing to replace their V10's. Just curious if you'll share what failure you've experienced that's requiring you to replace the entire engine?
Sounds like whatever happened has caused you to lose confidence in the V10 if you're considering a swap to diesel like the OP.
New meaning reman. They don't make new anymore do they?
As mentioned, looking at options. Doesn't have to be a 6.0 just like to know what's out there these days. Cummins would be great. Anyone on here done that yet? I have been out of it for a bit....
That's good to know. Wonder why the the dealer told me different? Maybe they make better margin on the remans?
What's your concern with a reman? Any parts that don't meet new-spec are simply replaced, and Ford has no requirements for core returns. When they run out of good core blocks, they just use a new one.
But more important, why do you think you need to replace yours?
I'll get the info this week about V10's within the last few months and I'll double check my comment of availability. I know we have replaced V10's and may be assuming it is Ford. I have a close friend that is parts manager I will check with and our fleet parts manager as well!
Confirmed, we have actually replaced 8 in the last year! High mileage, abuse, ect... Fairview Ford in San Bernardino is our source but try Capistrano Ford in San Juan Capistrano it's a little closer. Talk to Tom In parts.
Progress
Hello everyone,
I stopped by the shop today and brought Jason and the guys some pizza for lunch and had a chance to see the progress on the van. The motor and transmission are in and looking good. Thought I would share a picture.
Maybe next week we'll get to hear it run???
Any update on this Jeff or Devil Mountain Diesel?
Yes, the motor rebuild has reach the point where it needed to be put on hold, so that the new Timberline DIY 4x4 conversion kit can be installed. The guys at the shop have removed the old suspension and are starting on the new front suspension. The photo attached was sent to me last week.
Latest on gas to diesel swap
Gas to Diesel update
The van is DONE! Yes guilty as charged, my posts and photos were far too infrequent, at best. So now let’s recap this amazing project.
Our original plan was to use the “donor” 2005 truck to complete the diesel swap. But, we learned that due to the vast differences in so many of the small parts, it made more sense to acquire a diesel work van. We found one for 500$ in pieces on Craigslist. As time went on, we ended up using almost all of the diesel van, specific parts from this vehicle. Everything from body harness, to oil feed lines. This saved countless hours and dollars in parts and labor.
The 6.0 Diesel engine was completed and fully Bullet Proofed in house at DMD. After the engine was installed, we began the lengthy transformation from gas to diesel. Most of the effort involved focused on inspecting and replacing or transferring parts from our “donor” van. The entire firewall was prepped with “sound deadening” material. The engine was installed and the Bullet Proof Diesel remote oil cooler system was installed.
The following few weeks were dedicated to completing the factory Ford, diesel van reassembly. The ATS transmission was installed. The factory fuel tank was removed and shortened to clear the transfer case. The fuel pump and lines were all replaced with a FASS lift pump assembly.
At this point in the process, we pivoted into the 4x4 conversion. We ended up using front and rear axles from a 2005 F250. The four link conversion kit for the front axle was acquired from Timberline Vans in Colorado. This kit was awesome! It is a very complete and thorough kit. The installation is quite involved but straightforward, thanks to very detailed instructions. All components were welded up here, in house. Then the front end was completed, including new front brakes and steering components.
The Timberline kit can be run with the stock rear axle by using the supplied wheel spacers. Given the nature of this project, we felt it must have the F250 rear axle, to match the front. The rear axle was completely overhauled and a True Trac carrier was installed. The rear axle spring pads and rear shock mounts had to be cut off and relocated be for axle installation.
Next, came time for the transfer case installation. The Atlas transfer case was on back order so we pivoted to the factory Ford manual shift transfer case, which was obtained locally. It will be replaced with an Atlas transfercase after ski season.
With the running gear installation was complete, the next few months were spent dealing with the small “punch list” of items :
Rear drive shaft was custom built
Front driveshaft is a stock 2005 F250 front drive shaft
The transfer case shift linkage is part of the Timberline kit which was installed.
Parking brake cables were replaced with 2005 F250 cables with custom main cable.
All wiring was completed.
Both battery trays were installed.
Front and rear bumpers were upgraded to Aluminess products. The Aluminess running boards were also installed.
Lastly, the van was outfitted with new tires and wheels. With the following specs (35x12.5x17 BFG K02’s tires & Method 17x9” wheels.) The alignment was then performed in house, along with a complete safety inspection. All programming was brought to the current Ford van specs.
After the initial break in of the new engine assembly, all fluids were checked and the van was road tested. Our initial reaction was very positive. Any time you get a project of this magnitude, getting it back on the road isn’t always that easy. In this case, things went well. With that being said, the ride quality is remarkable, the steering feel is easy. The van is very user friendly.
With a few last details like mirrors, stereo, and the security system handled. We finally started to accrue mileage, which has gone well. I think the best feedback I can give about this van, is I would not hesitate to use any of these products again! In my opinion, it is the best riding van that we have been a part of! Especially, with the long term reliability of a fully BULLETPROOF 6.0, the durability of 3/4 running gear and the ultra “road trip capable” platform this van is a 10!
Well, certainly sounds like you navigated through all the hurdles. Quite the project. I would also like to see the end result... need photos to satisfy my curiosity!
Pictures
Here is one of its first trip to the snow.
New posts
