2010 E-350 SMB West built with 6.0 diesel
46 gal transfer flow tank
Fuel gauge started acting erratic. Showing half full when full, then swings to empty. Re start another time and it shows 3/4. Not ever accurate with approx 40 gal in tank. Ford diag showed bad fuel sending unit.
The part for this is obsolete and not made in aftermarket nor by Ford.
Ford has no solution.
I noticed that when fuel gauge shows near empty and the warning light comes on that the vehicle throws an error code on scanner P115A-60 Low Fuel Forced Limit Power. Basically when near empty with warning light showing only a few miles till empty (despite being full of fuel) it de fuels and limits power in an effort to conserve fuel.
My local diesel guru is looking to trick the gauge into reading full.
My understanding and experience is that my gauge reads approx 440 miles when I fill it till empty. It also seems to read full when it is full.
This means that the "bottom" of tank must hold the remaining fuel.
That said, if a stock 46 gal tank has stock sender unit, did Sportsmobile West extend the pickup to reach bottom of this tank?
Even if they did, when the gauge shows near empty, you defuel so the last 10 gallons is there but you would have limited power.
Any feedback is welcome.
