Hitch Box - StowawayMAX w Swing Away frame
1der
San Francisco, CA
$400 here on the Forum ( $750 plus new, $500 Craigslist). Hope someone needs one of these. :) Located San Francisco. I can deliver between SF and Los Angeles around the end of June.
Excellent Condition w Swing Away Frame for 2" receiver makes accessing the trunk or rear doors easy. Ivory color Item #: ST 024W
Large storage capacity in weather resistant locking box. Tail lights, key for lock, hitch tightener, and locking hitch pin included. Great for your SUV, truck, or van. Ready to go for your Spring and Summer adventures!
More information link:
https://www.stowaway2.com/max-cargo-carrier-black (this one is white)
Key Features:
Cargo Box
Molded from the same high-impact polymer used in white water kayaks
16 cubic feet of gear capacity
Carries up to 200 lbs
Locking latch for security
Two integrated taillights and wrap-around reflectors
Built-in carrying handles and a drain plug for easy cleaning
Weep holes to divert water away from your gear
Outer dimensions: 51"L x 23"W x 26"H.
Inner dimensions: 49"L x 21"W x 24"H
Box weight - 53 lbs
Designed for vehicles and hitches with a minimum 300 lbs tongue weight capacity
SwingAway Frame
Rises 2" - 5" for ground clearance
Pivots up to 180° for clear access to the rear of your vehicle
Frame locks at 90°
Heavy-duty welded steel with dual safeties
Frame weighs 46 lbs
