I just replaced my rear fixed glass windows with pop-out windows sourced from a local junkyard, and thought I'd share a short write up on how easy it was to do.
This install was on my 1998 Ford E250 EB SMB, but I imagine most 1992+ E-vans are the same. It took about 30 minutes at a leisurely pace. The hardest part was scraping off the old butyl window sealant.
Also see this thread on making screens for these windows: viewtopic.php?f=13&t=11256&p=104004#p104004
Supplies you'll need:
1. Butyl sealing tape. I used 3M Windo-Weld 5/16" tape in a 15-foot roll. I bought two rolls, as I have two rear windows and one side window to install. $12 per roll at Amazon: http://www.amazon.com/gp/product/B00063Z4FM. You can also use RTV silicone sealant, as JWA notes below, which might be a bit easier to handle (I might try this on my next install). $11 for a big tube at Amazon: http://www.amazon.com/Permatex-80855-Si ... 000HBNUFO/
2. Acetone and rag(s).
3. Latex/nitrile/vinyl gloves are handy, too, when dealing with butyl tape.
Tools you'll need:
1. Socket wrench with 10mm socket for window mounting nuts. I used a nut-driver handle so as not to put too much torque on the bolts.
2. Small thin, flat pry bar.
3. Utility knife.
4. Some sort of scraper. I used an old and somewhat dull chisel and a plastic body filler spreader.
5. Phillips screwdriver.
6. Sawhorses
7. Drill and bit to fit the latch mounting screws
Step-by-step directions follow...
Tools you'll need:
3. Utility knife.
6. Sawhorses
