dbhost
Let me be FAR more specific. I hate that I never use it as a dinette.
I am a single traveller, who will be adding a second as vacation and travel time allow. We NEVER use the dinette as a dinette. We sit outside of the van to relax, or work, or whatever, even it utterly awful weather we don't sit in the dinette. For one thing, it is too close to the ceiling to actually sit upright in it...
I always leave the bed down and made...
Because of this I am considering a bit of a permanent change...
Take the dinette halves, and chuck them in storage. Get some 3/4" plywood, cut to fit which happily is a standard US Full size mattress size of 54" x 75"
I believe I can stay same thickness, the OE cushions are ~5" and the memory foam topper I use now is 3". I can go with a single 8" memory foam mattress and more or less call it good, squish it out of the way when need be...
I want to rip the base long ways in half, add a piano hinge and a proper full size memory foam mattress... This should allow me to more easily access the storage, and fuse block / breaker panel that will remain in the same positions..
THAT actually just screams the inevitable question. Is there any of these mattresses that are set up to maybe bifold length wise?
This would allow me to add a partition between the bases, pull the vent for the heater, move it to the partition. This would allow me to greatly expand my electrical cabinet area and add a 2nd 400 amp hour battery... That, and enough panels / MPPT charging would allow me to stay off grid with actual AC...
I still need to identify what 12v compressor would work to replace the old StarCool compressor, and how to wire it up, but one piece at a time...
