Retrofireman
Advanced Member
- Joined
- May 3, 2021
- Posts
- 48
Has anyone had any luck finding replacement T molding similar to what Sportsmobile used?
After spending way too much time on-line looking for a match, I finally ordered mine through (now) Field Vans directly. That off center “t” is a challenge to locate.
A note about the width.. I also purchased this and it was a little too wide. After installing it I used a small block plane to shave it back to flush. The soft plastic is easy to plane off.I bought some from Amazon, but as Steve mentioned the off center T was a problem and the width didn't match exactly either. May just give SMB a call and see if they can sell me 100' of it or so.
Close on this color wise, but no cigar.
Yes, I bought a small roll of that also, but it's not the same one SMB uses. The color is the same as mine, but SMB uses an offset groove in their wood and so it needs an offset barb on the T Mold also, and it seems like the one from Amazon is a bit wider and more rounded than the SMB one. I haven't been able to find the exact match online anywhere. Thanks for the replies.This on Amazon - Amazon.com -- was what I used to replace my gaucho couch drop down panel T-moulding - about 3 years ago - color was "Dove Grey"
