Limit switch
KennyV
New Member
Hello all! I have a 2017 Promaster with Sportsmobile top. I'm in the process of replacing the rubber weather striping around the edge. The weather striping I'm using is a little thicker than original. I've noticed when lowering the top, there's a LOT of pressure on the U bars before the limit switch turns the motor off. This and the little thicker weather striping I'm thinking it may be good to adjust the limit switch. My problem is I can't find the limit switch. I'm hoping someone here can help me with the switch location.
Thanks much for any help! Kenny
I was able answer my own question today with help from Sportsmobile. I contacted Sportsmobile this morning, and stared looking and soon realized the motors are linear motors. So now I'm thinking linear motors have built in limit switches and about that same time Sportsmobile called back and confirmed, yep limit switches built-in. I'm very happy I haven't actually started applying new weather striping, found and ordered some same size as original.
