Loncoin II flooring - Sonic Gray
1der
San Francisco, CA
I bought 12 linear ft x 6 ft wide of the Sonic Gray #183 Loncoin 2 Featherweight for use in our build. Enough to run the full length and width of the interior. As of now, I have changed my mind and am not going to go this route as we currently have carpet through out and will stick with that for a while.
It is brand new, never unrolled. My cost was $386.22 out the door and I would like to get as close to that as possible. That is a pretty darn good price for this.
It is in San Francisco. I can drop it off next week pretty much anywhere along HWY 5 or 101 on my round trip to Los Angeles between July 12th and 16th. Shipping would be very expensive. thxs!
Hey Ray,
I have carpet currently. It's not glued down; it just floats over some sheet metal and foam sections and I rely on the factory Ford edge trim and various things that are bolted through the carpet to hold it in place. Would Loncoin work the same way or does it have to be glued to solid plywood?
Loncoin really wants to be glued down to something, typically plywood. I suppose it would be possible to lay it out flat and use as a mat ??
I was going to glue it to each of the three sections of plywood flooring I have in our rig. That would allow me to remove the flooring if needed.
I have someone that is planning on coming by this coming week. If they pass then you are next in line
