Looking for my gateway to adventure!
rmance
Hey all, I have been a member since 2009 so it's about time I introduced myself and more importantly BUY A VAN! I am finally at a point in my life where I can afford a van. Not cash but I am ready to purchase with financing ... which is my main question here. I have talked to a few finance institutions and they won't do long term financing on this thing called a Sportsmobile. They have no idea what it is! So where the heck does a person go for financing that understands what it is I want to purchase?
I live in Santa Clarita which is just north of Los Angeles. I make my living as a systems engineer at Technicolor in Hollywood. I am hoping to move to Show Low, Arizona in the next five years or so. My hobby is landscape/nature photography (which is why I need a 4x4) and motorsport racing (both motorcycles and cars) so I COULD use the van as a business expense, currently part time but full time when I "retire".
And of course I love just getting out and camping. I have two little travel buddies Annie and Lexi ... the best little wieners you'll ever meet. Hopefully I will be fortunate enough to meet some of you on SMB trips.
Till then,
Robert
I would hit up your local credit unions and ask about RV financing. If you buy a real name branded Sportsmobile, they are considered a Class B RV. The only hard part is determining value as the NADA guides don't accurately represent the prices these vans are fetching. Good luck!
I used my credit union that I have a very good relationship with through my businesses, still took some "convincing " to borrow that much for a 10 year old "van".
All of their research kept telling them it's just a van even though it had a motor home registration,I must have told them to research Sportsmobile 5 times. Persistence pays off ! Good luck with your search.
Rmance, I just went through this process. I tried a lot of different angles. In the end, I had two viable approaches, and a possible third approach. I used Option #2.
Option #1: Buy Used Through Sportsmobile TX or Sportsmobile North
(I did not end up using this option)
Both SMB TX and N have relationships with Bank of the West, and are able to obtain financing for their used rigs in this manner. Typically, this only works with the vehicles they physically have on display at one of the two locations, and that usually means a vehicle that is less than 10 years old.
Option #2: NADA Value; Credit Union or Bank Loan
(This is what I did)
This option takes more work, more patience, and potentially more cash.
First--Banks and credit unions will loan money for RVs based on their NADA values. SMBs are listed in the NADA RV guide. (Homebuilds do not qualify.)
The NADA value shown for most RVs in the US actually exceeds that vehicle's street price. This is generally the opposite for specialized Class B RVs, such as SMBs and Roadtreks. Street price for these vehicles is often higher than the listed NADA value. The reason for this is that NADA doesn't actually care what the street value of a vehicle is. They have a mathematical depreciation formula that they apply across the board to all RVs. They start with the list price, and then depreciate according to their formula on an annual basis. It has nothing to do with reality, but it makes the actuaries happy. Go figure.
NADA value is workable with SMBs--sorta--if you know how to work the system.
Challenge #1: NADA does not accommodate 4x4 SMBs until 2010. This means that every pre-2010 SMB is priced as if it were 2WD. There is nothing you can do about this.
If you are buying a 2010 or newer:
1. You can buy either a 2WD or a 4x4 SMB.
2. NADA value will probably be less than street value, so your down payment will need to fill in the gap. But you will get a loan for most of the purchase cost.
3. You can work the system to increase the NADA value. (I'll address this in a minute.)
If you are buying a 2009 or older (I bought a 2006):
1. NADA value will come up short, as usual.
2. NADA value for a 4x4 will come up an additional $15K - $20K short because they do not take the 4x4 conversion into account.
3. You can still work the system to increase NADA value. I'll talk about this below.
4. Bottom line: for a 2WD rig, this is the same as the 2010 and newer situation. NADA value will come up a little short, but you can get a loan for most of the purchase price.
5. If you want a 4x4, you have two choices:
a) buy a 2WD rig, get most of it financed, and pay separately to get it converted to 4WD. (This is what I am doing. The benefit to this is that I get to choose which conversion I want, and the conversion is 100% new for me.)
b) Buy a 4x4 rig, and pay a much larger down payment.
Sidenote #1: How to work the NADA system to increase rated value:
NADA starts with a set base value. They then add value for options. If you pick through the list of options on line, you can very rapidly figure out which options will add the most value to your rig. For example, they have an option called "Full Body Paint." There is no definition for this, but I believe this applies to RVs that have a fully painted exterior, as opposed to being fiberglass covered with vinyl striping. Full Body Paint is good for an additional $4K - $8K, depending on the rig. SMBs definitely have full exterior paint, so I ticked this box when I filled out my loan paperwork.
Bottom line: do your homework in advance. Make sure that you figure out which options NADA lists for your rig, and make sure that you get credit for every one of those options. It will help your value. When you go in to apply for your loan, come in with a sheet of paper that lists each one of those options, using the exact language that NADA uses. Hand that to your loan officer. That will ensure that all of those boxes get ticked as they are calculating your NADA value.
Possible Option #3: Appraisal (This MIGHT work, but it is pretty much a Hail Mary pass)
Some banks will sometimes accept an independent appraisal of your rig in the event that the selling price is different from the NADA value. I could write a book on how to get through the appraisal process, and I'm not going to do that here. Suffice to say that at one point I came close to buying an SMB, and I was going to use the appraisal route. My draft appraisal documentation came to well over 50 pages, and that was only the beginning of the draft.
Sidenote #2: NADA actually has records of many RVs by VIN. For example, when I did my loan for my 2006, my loan officer was able to find my VIN in NADA's database. That made my credit union happy, and it gave us a base value for the vehicle. To that, I added my list of options--the options were not included in the base value. By the time I was done, the NADA value was more than my purchase price. Happy me!
Of course, this was for a 2WD rig. I just wrote a check to Quadvan for my 4x4 conversion, so I didn't get away scot-free. ;)
Good luck with your search! These dang things are expensive, but they sure are fun! :D
Good luck on your search for your new LOVE!! We went through North/Financed since it was a new build...then we later cashed out some house equity and paid off the loan to save the 15 year loan interest money...doing that saved us over 30K in that period (on paper)...but the write off for a second home interest deduction was lost (though)...Or live in it for a couple years Bohemian style and make up the cash that way!!:d5:
Wow, great detailed explanation. Thanks for sharing that.
Robert, welcome to a great group!
Thank you so much everyone! I am very excited to be here and even more excited to know I'll be part of the family in January.
Glider ... I can't thank you enough! With all that fantastic info I'll be ready when I talk to the next finance person. My goal is to get "pre-qualified" so when the next van becomes available I'll be ready to move on it. I am so ready to get the next chapter of my life started ... at age 61!
A mere baby! Glad you're going for it!
This is the sign we have hanging on our wall at home and live by it every day:
Rmance, I was happy to help. Feel free to check in with me if you have any questions or run into snags. I'm glad to give you a hand going through the process.
Here's one more hint: when I showed up at the credit union to get my loan, I walked in the door with a three-ring binder, with labeled tabs for information on the van, and anything and everything the CU might want to know about my income, assets, debts, credit history, etc. On top of it all was a summary sheet that showed basic vehicle information, VIN, condition, and a list of those all-important NADA options. The goal was to blow the loan officer away so thoroughly that she would never think to question the van or its value.
The loan officer said she had never seen anything like it before--she literally went around the office and showed it to her colleagues. Loan was approved in less than five minutes. Guess my three-ring binder trick worked. :D
That is just brilliant! I am going to start putting one together this week.
Thank you so much for the advice. I am so glad I mentioned something! I thought it was a stupid question, but as they say ... the only stupid question is the one you don't ask. Hopefully it will help others as well.
Hey --- since this thread is already shaping up to be such a solid and informative ledger of great ideas for securing *financing* for a Sportsmobile....
.....it's probably worth addressing the topic of *securing adequate insurance for a used Sportsmobile.*
It's a topic that seems to have a wide variety of unique challenges and solutions. Another area, like financing, where you want to be informed and prepared well ahead of time.
A lot of these SMB's trade hands now for high-dollar, despite being over 20 years old in some cases. Getting an insurance company to agree to a true market valuation for insurance purposes can be a bit tricky. If you simply stroll into an insurance agency with the VIN number for your new-to-you (and probably pretty pricey) 2005 Sportsmobile, the insurance reps are likely to see it in their system as simply a 12-year old Ford Cargo van....and want to insure it / value it as such, according to depreciated NADA values for an ordinary cargo van.
Pretty sure I've seen some great forum threads in the past about this topic, might have to search and add links to some of those to this thread.
:b5:
Well now there's something I hadn't thought of! I just ASSumed it would be an inexpensive RV kind of insurance. Thanks so much for bringing that up Mike! Will definitely have to figure that into the cost of ownership. Now I wonder if Allstate will know what I'm talking about ;o)
I spoke with my insurance carrier in advance. I used the adjusted NADA value from the bank to establish initial value. I then gave them a list of planned improvements, (4x4, etc.), with costs, and got them to agree in advance to upgrade the value of my rig according to those costs.
I presented the list of improvements as things that would increase the safety and durability of the vehicle--for example, the decreased turning radius and improved roll stability of a Quadvan conversion, and the improved safety of Aluminess bumpers.
It took some doing, but presented in the right way, the insurance company saw this as an opportunity to make money on a vehicle that was safer than original. With each improvement I make, I send in the invoice to establish the increase in value, and they increase the insured value of the vehicle. Everybody happy. :h6:
Most of use do have normal RV insurance... Same caveats apply to any insurance, if it's stolen or totaled, they will lowball you, and there will be some negotiation... But they base evaluations on available comparable vehicles, so current market is factored in, not some depreciating asset table.
As others point out, there are also stated value and agreed value policies, which tend to be more expensive and have more hoops to jump through as they're designed more for classic cars and the like.
Do your research on Stated Value vs. Agreed Value. Make sure your agent knows what you want.
I would happily pay for either of the above policy types........Unicorns....in So Cal for an SMB type van anyway.....I've tried.....
Worth looking over this insurance thread:
http://www.sportsmobileforum.com/forums/f9/seeking-rv-insurance-for-4wd-new-smb-5412.html
I got a loan (new van) through my local credit union but did it as a second on my home. No issues with the loan but the insurance was kind of a nightmare. Several companies gave me a quote but in the end most of them said I couldn't get full coverage (replacement cost) or flat out refused to insure a vehicle that didn't have a fixed toilet and black water tank. Ended up with Good Sam National General Co. The bad thing was this all happened at SMB during the delivery date so I was glad I had checked with several insurance companies and had all the paperwork with me.
