Yes, it is a DRW front axle and I expect to keep the rear duallies, at least initially. May go to a rear SRW 10.5" later. I'm chewing on what to do about wheels and wheel bolt patterns. On my last Van I converted the stock rear axle lug bolt pattern from 8x6.5" to 8x170mm using quality adapters. I don't know yet if this is advisable or even possible on a heavy ambulance with duallies.
I too bought some axles! I went for front and rear 4:30 from a 2013. Planning on picking up my MG kit soon! I’m excited to get going on this conversion, but I have some questions for you all.
1) What are people doing for a cross-member? Can one mod the original, or do you need a donor?
2) What year front f250 and f350 driveshafts work for donors?
3) Those of you with the shift-on-the-fly nv273f, What has your experience been? Has it been worth the electrical hassles? I saw that somebody had agile off-road make them a wiring harness. I’ll have to call them and see if that’s still a possibility. Is a DIY install challenging?
4) My van is a 2001 5.4L with the 4r70. If I can find this transmission in 4wd would it be easier/cheaper to just swap that in rather than have my tranny modded at a shop? Any reason why that wouldn’t work?
Wish there was a van icon.cool guy will have to do. Thanks much!
1. You will be modifying the cross member in the van using the supplied template. It would be very difficult to remove and replace.
2. You can use either model front DS. It will have to be lengthened. (IIRC)
3. I went through the "electrical hassles" of doing Eshift on a previous conversion. It wasn't much of a hassle really. I would only say its not worth it from the perspective of it only gets you half way there. Shift on the fly would have the hubs lock/unlock too. It can be done. Shifft on the fly is great for snow driving. If you go wheeling or only need 4x4 for when you get stuck manual shift will suffice because you have to get out and lock hubs anyways.
4. If the new tranny is in known good condition sure. Seems like a time saver rather than having to wait for a rebuild.
Nice score on the 4.30's. Keep us updated on your progress.
B
I was talking about the transmission cross-member.
MG answered my question this past weekend. So I wanted to share it with other folks converting a 5.4 with 4r70. The stock 6.8L and 6.0L cross members are already 4" longer to clear the front drive shaft. Since the 4R70 is shorter though, you have to add a 4" block to space it back to the right location. I'll be on the lookout for a stocker from a 6.0L or 6.8L.
I will at some point do a write up of the ESOF install with pictures and part numbers list but for the time being, here's a quick run down.
(This is in reference to using controls from a ~2008-2009 NV273...probably the simplest set up there is for this tcase)
You'll need:
-NV273 Transfercase
-Connector for shift motor (available through Motorcraft)
-Connector for encoder motor (available through multiple sources)
-Shift module and grey + black connectors (2008 F250 PN-8C3T-14B205-A
-Mode select switch and connector
-2 12V automotive relays
-small aux fuse panel (I use this rather than trying to find empty fuses in the van)
The tcase has the two wires from the shift motor going to the two relays (we mount relays under the hood, left side of inner fender). Then 6 wires from the encoder motor to where the shift module is located (inside the van).
The switch will get a dash light wire, two wires to the control module and a ground
The shift module will need these inputs:
-12V+
-Ign 12V+
-GND
-VSS (see van's wiring diagram for easiest place to tap into this)
-Neutral indicator (essentially, the module is looking for a ground when in park or neutral)
-Brake switch
The module outputs to:
-4wd hi light (this wire goes to ground when in 4 hi)
-4wd lo light (this wire goes to ground when in 4 lo)
-6 wires to encoder
-2 wires to the vacuum hub solenoid
-2 wires to the mode select switch
-2 wires to control the relays
The vacuum hub solenoid has the two inputs from the shift module plus a 12V+ source. You "T" into the vacuum line running across the top of the firewall (it goes back behind the heater to a vacuum reservoir) and run the vacuum line to the solenoid. The other line splits to the two hubs. check valves before the solenoid and after the solenoid but before the split to the two hubs are needed (just like Fseries set up).
That's all there is to it.![]()
Micheal: Brilliant as always. Hopefully you have the time and the inclination to answer my specific question below.
My New Year's resolution was to have no more broken stuff. The Dakota, the Bronco and even the Corolla are all or are all nearly dialed, so I am stoked to start working on my van again.
Here's my specific question. My 2002 E350 7.3PSD Ext. van has the Borg Warner 1356 in the manual shift version. It slipped out of gear within the Salem-Kroeger warranty period and they replaced the shift forks. And it worked for a year or two, but later started happening again. I believe that the linkage is putting stress on the shift forks as the van body twists and wears down the plastic shift fork tips.
My 1995 Bronco and my 1993 Bronco before that also have (had) the BW 1356 but in the electric shift version - which I never ever had any problems with. I can get a used BW 1356 electric shift for relatively little money, but my desire is to use the 2007 F250 vacuum hubs which Salem-Kroeger installed (I have the 2007 F250 oem shop manual) by installing all of the requisite gear which you mentioned in your excellent post above.
The tail shaft on my van's originally 2x4 4r100 transmission was "replaced/modified" to attach to the BW 1356. Can I / should I just install a NP 273 electric shift instead of a BW 1356 electric shift? That way I would be doing the full conversion you mention in your post above, rather than doing some modified version of the Bronco-type BW 1356 electric shift with the 2007 F250 vacuum hubs?
I know I am asking for allot of free advice here. And I will respect you if you think I am asking too much.
Fox Shocks part number for rear shocks?
Anyone got the correct part Number for the rear Fox 2.0 shocks post lift.
