TROGR-SMB
New Member
Hello, I'm new. And I need help!
2013 Ford QUIGLEY E350, 4X4, 115k miles. I think the Front U-Joints are causing my issue.
When driving under 25-30 mph all is OK. Above 40 and it does not want to stay straight, above 50 and I can not keep it on the road. Feels like there is a dead spot at straight ahead and it falls off a knife edge to left or right. So if I'm going 40 and correct to the right, I start to go right, now correct to the left,and try to hold at straight, she drives left, wont stay straight. She continues demanding steering input left then right, wont stay straight.
Jacked up front axle, did the "grab the tire" thing for ball joint play- left/right-up/down = solid as a rock-absolutely no ball joint play. Then lowered Van and had son do the "10:00 to 2:00" thing with steering wheel while I looked at all joints, very slight hesitancy at Pitman Arm to Draglink.
OK - so I replaced the $300.00 draglink parts from Quigley. NO CHANGE.
I think "It's gotta be steering gear box, what else is left"-- --
So $600.00 from Ford - new steering gear ---- NO CHANGE #@^#$#@^%
With key in, steering wheel unlocked, motor off, wheels on ground, son did 10:00 to 2:00 again, hubs set to "FREE", watched as U-JOINTS acted like they were spring loaded, first not moving then move all at once, like pressure was built up on them.( non limited slip axle). He also noticed a hard spot at 12:00 or center, that was harder to overcome than at further left or right. I confirmed the hard spot. then I locked the hubs and hard spot went away.
So now I have it on four jack stands, so I can put it in gear. Rear tires on van - but off ground. Front tires off van.
Put it in 4X4 and watch as the front hubs go back and forth as the axle rotates. I HAVE VIDEO IF YOU THINK I"M NUTS. It looks like someone is turning the steering wheel from 11:00 to 1:00. The Right side (passenger) axle is wobbling inside the seal a bit more than the left side, but I think it's the dried out U-JOINTS causing my AGONY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The tag on the axle shows 2015892 1 , DANA XX201589201 , S/N 169WXX1317650046 , DATE 25-JUNE-2013. I find nothing at DANA web site.
If you can PLEASE offer any suggestions, I'm out of MONEY and Patience.
Thank you, Jeff
Thank you, Jeff
