Looking at the voltages this is definately a problem with the new alternator. The feed lead for the DC to DC charger did need to be moved for sure, but the voltage regulator should NOT vary voltage output that much, and the alternator MFG (Powermaster) agrees. They are shipping a replacement out on Monday.
The variation may have nothing to do with the alternator. This is speculation but if you install the new alternator and nothing changes you can explain it this way:
If you have a high resistance path between the Alternator and the DC to DC (strong evidence if you keep tripping breakers at input to Dc-DC)
For example any combination of the following:
- You connected to the start battery and have old and compromised battery connections to the alternator:
- You have dirty/corroded connections in your original wiring to the aux battery.
- The wiring is undersized over a large percentage of the total path length.
An oscillation can setup depending upon how fast the DC-DC convertor settles as well as how fast the alternator responds to changes in load.
When the DC-DC requires more current from the alternator (to maintain for example 14V @ 40 amps at the output), DC-DC the input current demand will rise proportionately higher for a larger path resistance to the alternator. A lower resistance will not require as much additional current demand.
As the demand increases it is more likely for the alternator to exceed its RPM-dependent charging capacity, which reduces the voltage output and further increasing the required demand.
As some point even with a disconnected ACC wire, the voltage will drop below 12.5 volts (disconnect voltage without ACC) and the DC-DC will stop charging and the current demand will drop and the alternator voltages will again rise to levels consistent for idle RPM without the DC-DC. At some point, the voltages are high enough (13.0 V without ACC) and the DC-DC turns back on again continuing the oscillation and voltage variation.
If these currents are high enough (and despite the on-off-on duty cycle) you will eventually trigger the thermal limit for fuse/breaker and it will reset (at the input to the DC-DC).
Based on what is happening, you might be safer to just connect your start battery directly to the lithium battery so you can at least see what your voltage drops/current draw is to gauge how much resistance you have.
You are more likely to under-charge the lithium with a direct connection and you can see where you are at with your connections without fear of tripping a fuse/breaker.
Note the difference between 12.5 and 13.0 for turn-off and turn-on is used to guard against the type of described oscillation, but if the resistance is too high , then the 0.5V spread is insufficient to keep from oscillating
