Newbie question about the Lingo
catinmoon
Advanced Member
HI all,
I've been on the lookout for a Sportsmobile for a while and just ran across this forum. It's obvious there is a lot of group knowledge out there to take advantage of.
One thing I am encountering is there are a lot of abbreviations and general lingo that I can't quite follow. So I'm hoping that there might be an old post somewhere that is a dictionary of sorts that will help me understand some of the posts.
For example, I'd really like to find a shorter length, smaller engine, 4 or (front wheel -does that exist?) van with lots of windows. But I'm sure you would say it differently. What should I be looking for in terms of keywords?
Translation?
Thanks much,
SJ
Ford bodies
RB: regular body (shorter length)
EB: extended body (longer length)
Ford bodies
cargo van (minimal factory windows)
passenger van (lots of factory windows), sometimes called a wagon in Ford-speak
Ford engines
V10 gas (6.8L)
V8 gas (5.4L)
7.3L, 6.0L, 6.4L diesel engines depending on year
From Ford, all vans are rear wheel drive
4x4 conversions (U Joint, Quadvan, Sportsmobile, Quigley, Advanced, sure there are some others)
I'll send you the link to my web site shown below...that might help.
There are many lingo shortcuts, probably too many to list.
Just something like Day/Nite shades might throw you a loop.
Translation?
Thanks much,
SJ
I'd start by reading a lot of old posts, threads, etc. You'll find yourself fluent in SMB'ese fairly quickly.
As for what you mention, when it comes to Ford vans, at least, a shorter length is usually an "RB", a smaller engine - well, you'll have to read up on the different engines, but a "5.4" or a "V8" qualify as small for these trucks. Older ones have different labels, such as a "351". Again, read up. No front wheel drive, but look for "2WD" for two-wheel drive. Window vans are sometimes called "window vans" or "passenger vans," as opposed to "cargo vans" or "work vans" or, my favorite appellation "plumber vans."
good luck, and keep reading. welcome.
paul
Thanks! All this helps. This might be a silly question, but with so many companies doing 4 x 4 conversions, why doesn't Ford do their own? seems to be a demand...
SJ
The turn key vehicle used to be Quigley from what I was told years back. I could be wrong. Today Ford only warranty's SMB conversions and not the parts SMB has added/changed. The extended warranty has change in the past and can at any time in the future. Why Ford didn't supply a converted vehicle is probably due to the local companies out there doing it. Most ambulances don't require 4x4.
You mean the company that cancelled production on the best selling commercial van platform ever?
:g3: Don't just blame Ford; we're under pressure to be Euro in design by good ole uncle sam. Hell it won't be long and this will be the accepted style of pickups :d7:
On the subject of engines don't forget the humble 4.2L 6 cylinder. It gets very good MPG (in comparison to it's bigger brothers).
If new, and if you're looking at Sportsmobile conversions, then the Sprinter. Six cylinder diesel.
If looking used for Sportsmobile conversions, also Sprinter. Not many full sized vans with 6 cylinder engines, and none by Ford since maybe the late 90s?
A smaller engine in a standard SMB (Sportsmobile) conversion would be pretty stressed, unless diesel, like the Sprinters. They do appear bigger, but in fact they have a good turning radius and aren't as ungainly as they may appear.
I get the impression you're looking for something smaller than a SMB. There are still lots of VWs out there, but they're getting harder to find and have some obvious disabilities. And don't even think about Eurovans. But check this page out; this dude is one sick van fan:
http://zenseeker.net/Kid/AdventureVan.htm
I think he wound up with a SMB, but boy did he find some cool vans (octopup?)
And I've been wondering about the backpacker eurotrash Burner rental specials I've been seeing lately, like Jucy and Wicked (if you're old here's what I'm talking 'bout: http://www.examiner.com/article/jucy-re ... s-by-storm). Somebody is converting those vans, ususally mini vans, probably with FWD (front wheel drive) and V-6s, and maybe you can find out who does it. Some are rather nice, and I think one of them may even offer 4x4. If you find out, let us know. I haven't been able to.
Rob
catinmoon said:
..For example, I'd really like to find a shorter length, smaller engine, 4 or (front wheel -does that exist?) van with lots of windows. ...
If you specifically want a Sportsmobile brand camper conversion, you would have to go back into dim history to get a shorter length smaller engine. For the last 25 years or so, the Ford or Chevy 138 inch wheelbase (R:cool: is the shortest. The Sprinter comes in several lengths but the shortest Sportsmobile Sprinter was about the same length as the Ford RB.
If you are interested in other brands of camper conversions or some type of Do It Yourself, there are a couple more options. Sprinter did make a "shorty" van about 24 inches shorter than the standard unit. It had a 5 cylinder diesel (maybe a very few gasoline ones running around) and rear wheel drive only. It only came in a standard height roof.
The Chevy Astro/GMC Safari van was made for several years. It was about 24" shorter than the standard Ford and a little narrower. It came in rear wheel drive or All Wheel Drive and had a 6 cylinder engine. Several conversion companies made campers and some can still be found used, including ones with pop tops. This one is probably your best bet based on the criteria you listed. Not available new.
There is a company in Canada that makes camper conversions for front wheel drive minivans like the Toyota Sienna, which was available with all wheel drive at times.
Can't forget the Volkwagen vans - the old bus, the Vanagon, and the Eurovan. All were made into campers at various times by various companies. There is a thriving market in rebuilt Vanagon camper vans, including retrofits with Subaru engines. The Vanagon and Eurovan were available with 4 wheel drive.
And lately there have been rumors of new Euro type vans - the Fiat type by Dodge and the Ford type by Ford. They all have small engines. The Fiat is front wheel drive. Don't know about the Ford. None are available with 4 wheel drive in the USA.
thanks again for all the ideas. I looked at and drove several vw vans, even rented a westfalia for a trip to No. Cal, but as much as I like the layout and the size of them I just don't see them as a reliable alternative for someone such as myself who is not mechanically ambitious. Although I did once fix my Datsun 810 station wagon on the side of the interstate in Louisiana with a hairpin, no lie, got me back to Baton Rouge. But they don't make cars that simple anymore.
I also set myself up to rent an Escape campervan, when we showed up at the rental place they couldn't get it started. So regardless of what that indicates, I didn't get a chance to fully experience that, except from my rear view mirror as I drove off (wait, wait we got it running!) -- no thanks, not where I am heading.
So you are all very intuitive, but everytime I see a SMB I think it seems the perfect solution -- dependable, sturdy, packs a lot into a little. However I am also open to learning more about the alternatives, for example any links to the Canadian company that does the conversions?
I appreciate folks' time listening.
SJ
Do want.
GTRV
or import something that is like +15 years old, there are several :c4: members- some even in good standing! :b5:
I thought I read somewhere that Sportsmobile will also retrofit a van if you bring it to them --- or am I imagining that. My guess is that it would be more cost effective to find one already modified that meets or closely meets my wants.
SJ
Depends on which site, what their work load is, and how old the vehicle is. SMBW has been putting tops on older vehicles.
