Vincent:
What are the dimensions that you need for D1/D2 and G1/G2?
..assuming D1=D2 and G1=G2
EDIT: I see that D1/D2=26.97mm......still need G1/G2
Check out this video:
https://spicerparts.com/videos/how-to-identify-spicer-driveshaft-series-and-universal-joints
Here are the measurements again thank you
They do make a UNOINT that converts two different sized yokes. Are you saying two sides match up and two sides are wider/smaller? I can get the part number for the one I am aware of if this is the case.
Vincent...this has proved to be a bit of a challenge.......
Your image above shows both the yoke width and end to end bearing cap distance to be 95mm.....
Can you re-measure the width of the U-Joint end-to-end across the bearing caps?
If they are 92mm end-to-end there are lots of U-joints that size......
A 95mm yoke width with 1.5mm retaining rings would need a 92mm wide U-joint.
thank you, that one also works normally?
https://torqueking.com/product/40940/qu40940-1330-series-ez-grease-external-snap-ring-u-joint/
