Pimpon new loc lights
Vincent here are several Vantage Optics Threads:
FYIW:The HID's do require wiring in a ballast & the LED's do not - I've used both and you can't go wrong with either, but would recommend purchasing the side marker light replacements at the same time (also available from Vantage Optics):
https://www.sportsmobileforum.com/f...n-hid-projector-retrofit-lights-14304-73.html (Last post has a current "Discount coupon code")
https://www.sportsmobileforum.com/forums/f20/vantage-optics-headlight-swap-32238.html
https://www.sportsmobileforum.com/f...-led-headlights-and-reverse-lights-31640.html
https://www.sportsmobileforum.com/forums/f14/2002-smb-e350-best-headlights-hi-tech-30434.html
As far as the tail lights go, I used these (and pleased with them, but are several versions available out there when you do a Google search):
https://www.amazon.com/Parts-Go-199...0+rear+led+tail+lights,automotive,105&sr=1-27
I thought I may have copied the link incorrectly, but when I open the link it shows the product with no problem...here it is again (and shows it is 'in-stock'):
EDIT: Now Amazon has a message which appears across the top of my page that states " AmazonConfirmedFit: This does not fit 2006 Ford E-350 Super Duty".
I can only assume someone must have reported it doesn't fit, Yet I ordered these and they fit fine (& have been on my Van several years with no issue). Maybe they changed something over the past couple years. The ones you linked look good also.
I just looked, it's not easy to order, there are options and I'm afraid of making a mistake
https://www.vantageoptics.com/shop/...D-Projector-Retrofit-Headlight-Kit-p366172879
Can you order my rear lights because Amazon does not want to ship
https://www.amazon.com/gp/product/B0015PPX4W/ref=ewc_pr_img_3? smid=ATVPDKIKX0DER&th=1
Sure Vincent, I'll gladly order & ship again :d3:
Are you sure the link you supplied will fit your Van? I am no expert, but do not see any mention of an E-350 Econoline Van???
Being a considerably larger box than what the differential Bolts were shipped in, the shipping cost will probably be about the same price as the tail-lights...are you OK with that?
Also Vincent, PM me again about the Turbo - you sent me the links for 2 Web sites but they were for the 'home' page - you didn't specify what you wanted ordered.
Again, the weight and size on the turbo i'm guessing will run upwards of $250+ to ship to France.
Whatever parts you decide on, just order & Pay BUT have them shipped to my address (same as before), then I'll forward to you.
Being a cheap wad, I prefer to change the individual bulbs. These are the brightest by far I have found. They have a mini projector on the end which is substantially brighter. Comes in different colors.
https://www.amazon.com/gp/product/B00PHUMFEW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B06XSQWY75/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00NPIUFMM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Also, be careful with changing Incandescent to LED. it can screw up the cruise control brake switch sensing. I have bought some load resistors to overcome this but have not tried it yet. Since they are brakes you would only need one resistor on the whole circuit.
https://www.amazon.com/gp/product/B0838XHWR5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
indeed it is not indicated E 350....
Felix if the link works for you order me thank you
https://www.amazon.com/Parts-Go-1995...,105&sr=1-27
Vincent, please clarify for me which one of the tail lights you are interested in and I'll order (#1 or #2):
https://www.amazon.com/gp/product/B004I5O70C/ref=ox_sc_act_title_6?smid=ATVPDKIKX0DER&psc=1
https://www.amazon.com/gp/product/B07N8L7ZQY/ref=ox_sc_act_title_8?smid=A21V9Z82905EPU&psc=1
Also, I have not heard back about the Turbo - if it's easier just provide me the Brand name & Model which you are interested in (as much of a description as possible) and I will see if I can locate the best deal currently available for you. ***Same goes with anything else you come across.
this model
