Popping my top
boywonder
So Cal
or......"getting the cart before the horse"........
So, I bought a pop top, now I need a van.
The plan so far is:
pop the top off of the donor van Done
Refresh the top while looking for a van In process
pop the top on the new van Need the van first
I ended up buying the top that was discussed in this thread:
viewtopic.php?f=24&t=11696
Here are a few pics of the removal process:
A nice shot of the condition of the top after giving the van a bath
Cutting the butyl seal with a (broken) guitar string and a couple of wood handles
Separating the double seals at the front and rear
Canvas separated from the van
Covering the butyl goo with packing tape
Ready for lift-off.......
We have lift-off!
Here is the (condensed) procedure of the removal process:
Note: This is a least a four banana job.... probably more like five bananas in terms of skill level, and there are a couple of steps that are dangerous and may result in death, dismemberment, maiming of a loved-one etc.....Please don't try this at home! The springs in the lifting mechanism have lots of stored energy and need to be treated with respect.
Step .5-spend 2+ hours driving the donor van from San Diego to Orange County for the extraction
step 1-remove all of the upholstered trim exposing the mechanism, and disconnect the wiring going to the top.
step 2-remove the screws around the perimeter of the canvas that attach the canvas to the roof.
Step 3-use a guitar string (actually about 5 strings after allowing for breakage) to "saw" the butyl sealant. I used only the smallest two strings on a guitar since I didn't want to use a wound string. I now need to re-string 3 of my guitars since I cut the strings off in the heat of the project. The long sides are easy to saw through; the front and rear ends have 2 rubber seals, we cut above the seals leaving the the seal and staples on the roof for removal after the top was removed. I have no idea why there are seals only on the ends (and around the corners for about 6")....If anyone can enlighten me, it would be appreciated.
Step 4-use tie downs and packing tape to raise the canvas in preparation for lift-off. We applied packing tape to the butyl sealant goo on the bottom of the canvas to prevent it from getting all over the canvas. Remove the plywood slider-block thingies that attach the top to the lifting bars. Note: when these are removed the top is just "sitting" on the bars thanks to gravity. I used my neighbor's driveway since this step required a flat surface (my driveway is ridiculously sloped).
Step 5-call a couple of your strongest friends/relatives and lure them to your house with the promise of beer. Lift off the top. It took two of us standing on milk crates/step stools to lift the top over the mech. I elected to do the lift-off with the top up as the springs will be (mostly) unloaded. As seen in the pics, we placed the top on 2x4's between the van roof and a pair of ladders.
I considered tying down the lifting mech with tie downs to remove the top, but releasing the tie-downs without the weight of the top would be very dangerous so we went with the "top-up" method.
Step 6-use a come-along to remove the chains from the springs and slowly relieve the load on the springs. Of course we didn't have a come-along and instead we used a cam-type tie down and the strongest person in the group to pull on it NOT RECOMMENDED.....and, as usual minutes after finishing this step I found a pair of ratcheting tie downs under the passenger seat of the van. These are also not recommended but are better than a cam-type tie down. Don't forget to hold the scissor bars up when releasing the second spring.
Step 7-unbolt and remove the mechanism, springs, etc from the van, and take lots of measurements of the giant hole in the roof, they'll be needed later.
Step 8-lather up with sun-screen and drive the van back to it's owner in San Diego.
Next step will be to refresh the pop-top since I don't have a van to work on yet.......
Boy (no pun intended) that sounds like a stupid plan, so stupid that I could probably be found guilty of doing something like that too. :f2:
Good luck with the build, once you get a van that is. At least you have a parts donor van if nothing else.
No donor van here, I just bought the top.....note step .5 and step 8 above.....
I'm assuming that this top is plug-n-play for a newer (2008+) econoline.........
Can anyone confirm this, i.e. has the roof line changed at all from 2003? (this top is from a 2003 E-150)
I believe the roof is the same from 92 up. It might be easier if you are putting it back on the same body (RB vs. E:cool: length. Looks like the donor was a regular body, and if so the top would look quite short on an extended body van - but don't let looks stop you. Another forum member put an EB top on an RB, so it can be done.
Great, just what I was hoping.......
I'm looking for an RB, that's why I picked up the top
From my experience looking for top quality used vans they are quite plentiful, at least in my area and within a close enough driving distance for the right one. Having this top ready to install soon after the van is acquired cuts down on waiting to afford or find a top.
Assuming you got this top cheap enough? And what was so wrong with the donor van that it became a donor van?
If I want a white cargo van they are a dime a dozen.....I don't want white, and I'll probably end up with a window van, although a cargo would also work.
The donor van was hammered; high miles, needed body work, has a side slider, and was white.....I'm looking for a 2009 or newer, the donor was a 2003.
Did I read correctly that you drove the van 2 hours back to the owner with no roof? The ultimate sunroof!!
Yes....on the 5 freeway.....and for all I know the owner may be still driving it. It won't rain a drop here until about Nov, so he's good for a few more months at least :a1: I mentioned to the seller to pick up some sunscreen and leave it in the van.
I've been reworking/refreshing the top, hopefully I'll get some pics posted today.
Try http://www.workvehicles.net/ They have a huge inventory in Fullerton. Seemed a little (or a lot) sleazy but since my van still had a factory warranty no worries.
The aux battery was toast and the spare tire didn't fit the van. Other than that I had to get 3 warranty repairs - fuel level sensor was bent, loose wiring in the dash caused a dead van, and loose wiring in the dash caused dead panel lights.
Good luck finding a non-white cargo van. It took me several months of searching to find one. Might be easier to find a non-white passenger van, but most of those seem to be the extended version. But it can be done, I probably saved $6-8,000 vs. buying new after all the hassle and repairs.
This bears a close resemblance to the process I followed. After lusting after an SMB for quite some time, I found an old donor top at a reasonable price and then started looking for a '75-'91 Ford van to put it on. Have fun cutting that big hole!
What I'm amazed with is the fact you convinced/negotiated someone to take the top off of a van that they would own after the fact. Maybe I should try that with some of the vans in the classified section.
my air chisel is looking forward to it.....just need a van.
Here are a couple pics of the roof cut from the donor; I'm hoping for a cleaner cut than these.....
The chimsel (detroit-speak for center high-mounted stop lamp) in the top is simply held in with caulking/sealer....I was hoping it was mechanically fastened....
The tail light wiring was simply twisted together and taped.....no butt-splices or other connectors...
The last surprise for the weekend was when I removed one of the headliner panels; it's holding the canvas to the roof. I'm planning on modifying this a bit.
Well, the seller needed cash and it was a better idea than selling a kidney :a1:
Since I don't have a van to play with yet.......
I removed the 1/8" plywood headliner and re-attached the canvas to the top using thin (5mm) plywood strips ripped from a 4'x4' sheet from Lowes.
This will allow much easier access to the underside of the top for wiring mods, leak repair, etc without having the canvas falling down.
I used the removed headliner panels as a pattern for the screw holes in the strips. The strips are in the same holes as the headliner around the perimeter of the roof.
Using the headliner panel as a template
strips screwed in holding up the canvas
This is what the underside of the top looks like......reflectix removed
My plans for further top mods are (in no particular order):
Install Yakima tracks
Install a solar panel; poke a hole in top and add connector
Fabricate new headliner panels and cover with padded headliner material
Replace fluorescent fixtures with LED fixtures
Replace edge trim on top (already ordered replacement trim and roof tape from SM:cool:
Replace high mounted stop lamp (ordered new one from SM:cool:...the old one is serviceable but a new one was $12....
Sleeve crossbars with cro-mo tubing and rework pivots with shoulder screws, etc.
add additional reflectix under top
prime and paint top van color (need a van first!)
You got that, I was seriously thinking about going that route after seeing it but another 2k is not in my budget.
Jealous....................................................................................................................................
If you find a van with a PH already on it you can install that one on mine.
Yes, I couldn't help myself.....and the seller was motivated.
Your van is an EB body, correct? This top is for an RB body van (which is what I'm looking for)
