Has anyone heard or have experience with the IcyBreeze portable A/C? Saw this posted on advrider, I believe.
https://www.icybreeze.com/
REF - I would be curious if you had any feedback from the guy you know that installed one???
I was thinking about times when I don’t want to run the Starcool because of power and having to run the generator when boondocking.
I haven’t done a good job of exercising the Starcool because of 30 amp access, or lack there of, but will do better going forward. I think I will run it monthly when I exercise the generator. I had some recent problems, much to do with weak 5-year old batteries I think, but the Starcool is running fine now after some fiddling with my 12v power system. I will likely need to replace the Tripplite at some point.
Thanks for the info on the device, it is what I figured. Might work when not too hot and you aren’t cooling an entire space.
Danhard makes a Soft Start box for the Starcool that easily permits a 15 amp usage either by Honda generator or mains power using the Tripplite
