Post reliable mechanics you've dealt with
Hi DaveB,
Any recommendations for good people in the SF Bay area?
Thanks in advance for your reply,
Malcolm
Hopefully one of the bay area guys can chime in. During my warranty I considered using Towne Ford in Redwood city because the manager Jay Mento was (is?) affiliated with Sportsmobile West. Not sure of their quality then or now but felt better having someone that at least knew what a Sportsmobile was. Jays Performance Diesel is starting to do a lot of diesel work in Fresno for SMB. Justin seems to know his stuff and they did a good job for me. Zilstra's Automotive rebuilt my engine and did a good job but a little pricey & about 45 min S/O SMBW. Valley Hybrids in Stockton was recommended by Advanced Adapters as a repair shop for the Atlas transfer case. They are a 4x4 shop not an diesel shop so to speak. Good luck on your quest.
Dave
Just wanted to post a big "thumbs-up" for the guys at Devil Mountain Diesel in Concord, Ca. Mark and Jay have gone out of there way to keep my 7.3 van running tip top. Honest, reliable and smart guys.
Best Diesel Mechanic in Loveland is Performance Diesel and Auto 1125 S Garfield Ave, Loveland, CO 80537 (970) 667-7396 Talk to Jessie. They work on my rig and I wouldn't go with anyone else in the area now that I've found them… Knowledgeable, reliable and reasonable on Price at $90 an hour.
I can vouch for Tuttle-Click's Capistrano Ford, and Rich Rader, the service manager. He took special interest in my SMB and doggedly pursued and fixed an issue which did not show up as an error code, thus took some time to track down. Had gone to a couple of other mechanics over several months period who could not identify the condition.
Golden Nugget Automotive, just off 395 in Gardnerville, NV. We pulled in with a bum vacuum pump on our 6.0 PSD Quadvan. They had the part and had us fixed same day, a couple weeks ago while we were traveling. Great people and the mechanics were friendly and knowledgeable. They were familiar with the van situation and understood our need to to be back and going quickly!
Don't have a shop I know of in Colorado Springs, ****, I can't even find a descent diesel guy in Boulder, I had to venture out to Longmont, not far, but far enough to be a PITA to get to/from drop-off/pickup.
Anyway, I went to Lucky's Diesel shop in Longmont on a recommendation from my old mechanic that can't work on the van anymore because it won't fit on the lift with my new CCV top. Things were promising as Lucky's had a few other SMB's and vans on the lot but it turned out to be a complete disaster for me, I would NOT recommend!!
Went in for an oil leak last year, came out with a new HPOP and still leaking, they failed to even perform a complete oil change with a new filter, so the bottom end of the oil system, including the pooling oil on the filter wasn't even addressed! Took it to Grease Monkey down the road for them to tell me my filter was indeed loose!! While at Lucky's I also had them check and tighten my emergency brakes, said my rear rotors were shot, and new ones included new e-brake shoes, I got new rear brakes, but it didn't improve my e-brake issue.
Fast forward to a few weeks ago when BOR was installing the FF, I noticed the e-brake shoes were old worn out rusted units, WTF! Not only does Lucky's do shoddy work, but they're crooks too! Charged me for parts and labor on a job they didn't even perform or for that matter address the original issues.
Anyway, my rig is currently at my old mechanics getting a new water pump and other cooling related bits installed. They were kind enough to take it in for this particular fix as it didn't require the lift.
Recommend-
Pellmans Automotive in Boulder, CO
Some PNW area additions below ... AND request for recommendation for Seattle area 90-100k tune-up (esp to replace spark plugs affordably, and *knowledgeably*, given the 2000 Ford E-350 spark plug threading/breaking challenges. I don't mind driving a bit out of the way for excellent affordable work, esp for mechanics amenable to educating me along the way.
A bit of a drive from Bellingham but Auburn Off Road are great guys, just did some brake work for me.
1. "Auburn Car Repair and Offroad" also did good work for me (though overcharged) when I visited them for advice on improving steering stability and perhaps installing a RedHead steering box (manufactured in their neighborhood).
On my initial drive from SanFrancisco van pick-up to Seattle, the van was pushed all over the lane by a bit of wind, or a passing truck, and/or highway curves at highway speeds. I knew the steering box needed replacing (if you're of the opinion that these boxes shouldn't be 'adjusted' when things loosen up). Auburn Off Road diagnosed and Replaced my track bar bushings and tightened the bolts on the Pitman arm, which noticeably improved steering wander. They did it while I waited, but charged me two hours instead of the verbally-quoted one hour (total bill $273, probably including WA state 10% tax, but can't remember). I questioned it, but didn't have the presence of mind to push back in the moment. Still, I didn't return to them a week later when I decided definitely to go with the RedHead.
2. ALSO RECOMMENDED, "Dave's Valley Auto" in Auburn, WA installed my Red Head Steering Box, and had done several of them, given they're only a couple miles away from RedHead. They were familiar with the unit and the potentially cumbersome procedure (especially for out-of-town shops) of returning the replaced unit to RedHead so I could get my deposit back immediately. I knew of the QA issues associated with RedHeads (and a couple seattle mechanics wouldn't install them any more after annoying time-consuming incidents). Dave's Valley Auto gave me confidence in driving across country immediately with a theoretically potentially troublesome RedHead by explaining their nation-wide support/warranty arrangement, how to follow-up if I had a problem, and how to monitor the RedHead for a leaky seal (the main QA issue). As it happens, the RedHead improved steering wander greatly, and was in great shape, no leaks, one year and 13k miles later when it was professionally inspected (at another great shop, SW Florida 4x4, a couple miles from my home in Bonita Springs, FL of all places ... post to come later on them).
Boulder Off Road in Erie, CO has been great for me. They understand Sportsmobiles with Quigley 4x4 kits.
ATLANTA AREA FORD MECHANIC -> Ford Performance Specialists
If you're looking for Ford (gas or diesel) work near Atlanta, GA, I have a new fave mechanic (for those times I'm driving out of Florida in a generally NW direction ;-). I found this guy on Transfer Flow's list of certified installers, simply because I preferred to find a mechanic *familiar* with the systems to help me diagnose a semi-related possible safety issue (mild gas fumes smell only when PUMP ON from Aux to Main tank), not because I expected or needed him to service or even diagnose my other Transfer Flow system issues (topic for a different thread). Yelpers, esp ford diesel guys or performance SHO types loved Doug and considered him very affordable. Anyway, I feel completely confident recommending (as do many Yelpers), Doug, proprietor of:
Ford Performance Specialists Inc.
351 Six Flags Pkwy SW, Mableton, GA. 770-949-7191, https://www.mabletonautorepairservices.com/
Doug $95/hr. $500 spark plugs. 20 yrs in bus. Great educator!
Though he (actually his one assistant) only did an oil change ($35 for my V10, $125 for a diesel though) and a safety inspection addressing my particular questions, he responded spectacularly to my statement that I wanted to learn how best to care for the vehicle and learn as much as possible to monitor issues, respond in the field, etc. He spent at least an hour, over the course of my visit, just answering my questions, recommending best practices w/justifications, and providing a lot of technical detail to educate me on the whys and wherefors. He brought me in for another 10-15 minutes at the end with my van on the lift to point out a bunch of stuff, ID-ing components (I'm a noob), identifying seeps/leaks to watch, and which to leave alone until some other symptom (or check engine light) alerted me to the actual need for service, etc. I would have had him do my spark plugs (at $500), but he'd already squeezed me in last minute on that Friday and didn't have time.
All in all, his safety inspection with my particular points of interest resulted in his walkthru and:
- No *liquid* gas leaks/drips found (comforting!); Verified he smelled gas fumes too, during PMP ON. Said I need a vapor check to find it but ok-ed driving with it (which I had been doing for 15k miles). He hypothesized that maybe the charcoal cylinders/filters are saturated?
- Cooling systems (OK).
- Exhaust Manifold Studs (1 missing, don't service until I hear the 'clicking' of exhaust leak),
- Power Steering (OK, slow leak/seep of Transmission fluid; wait until there's a problem),
- Quigley Rear drivetrain / pumpkin after backing into tire-sized ditch (fine, “can't hurt it“).
- General Advice: CEL, or poor function, will tell you when work is needed; else wait to fix. Change oil every 3000 (frequency way more important than type of oil, supported with personal anecdotes ;-). Get tune-up @ 80k.
He ended up charging me an hour of time plus oil/oil filter parts cost ($21) which I considered money well spent for my goals and purposes, and the convenience of getting on this busy shop's schedule. [He'd had a Ford E-350 Quigley diesel on his lift the day I called for an appt.]
Why did I seek out service in Mableton, GA? I was hitting the road from SW FL to Seattle this past July, after finally having the chance to get organized and research/address some of my less urgent van issues or simply check/monitor some of those things (eg, rotting exhaust manifold studs) I'd been warned about on 2000 Ford E-350 V10s. I didn't have time for another round of service in FL, so checked out Transfer Flow installers along my route. Many TF installers aren't mechanic shops, so this guy stood out, esp given excellent user reviews. He amazingly squeezed me in on a days notice for Oil Change and 'safety inspection.'
2003 E350 Quigley 4x4, What have you done to improve the ride?
My Van is at SMB West, once they do there thing to it I want to take it to a off road high performance shop to have the suspension, and stabilizers upgraded, what can you suggest for this rig to be at top performance?
This is just a one-off, but I took my E-250 EB to Fairview Motors, Brakes & Alignment in Goleta, CA to see if they could do anything about it wandering all over the road. They went through the front end and told me everything was in good shape. They touched up the toe adjustment, which made a dramatic improvement. They seem well-versed in twin I-beam suspension, and they didn't try to upsell me on anything, which I consider a good sign.
The mechanic that I have been going to for years is slowly winding down his business. As a result I asked him for a recommendation for another mechanic. He said Bridgetown Automotive on McLaughlin Boulevard in Portland, OR.
It turns out that these guys are experts on Ford vans. They have several commercial contractors as clients. The contractors fleets of 80 or so vans that are all E350s with 5.4 V8s. Many of the vans they service have 200,000 to 300,000 miles on them. There are even several that have gone 500,000 miles. Chris, the owner, said that engines will run long time if they are kept cool and have oil in them.
Because they have been working on the 5.4s for so long and in such quantity they know about what mileage certain systems will fail or need attention. He was able to look at our van and it’s mileage and know exactly what the problems we were going to face and about when. He was right.
I have been very pleased with their knowledge and expertise as well as their customer service. Your experience may be different.
6.0 psd mechanic in Utah?
Great thread!
Looking for a mechanic in Utah (SLC or Provo area). I’m having a hard start problem I’d like taken care of.
