geoffff
Hey RB50 and EB50 owners --
My plan is to do the same with my new house electrical system. It's a tight fit, but I think I can make it work.
Here I am doing some test placements, with my Victron 30A DC-DC charger, and the huge AcoPower all-in-one solar charger / inverter. I still need to add those two 4" furnace hoses, some Blue Sea switches, bus bars, fuses, cables, etc.
However, someone just pointed out to me that I may not be providing sufficient airflow for cooling, especially for the 3000W inverted in the AcoPower all-in-one solar charger/inverter pictured above. (I don't plan on actually using anywhere near that much inverter power in real life.) Sure enough, AcoPower recommends 8" of clearance along the sides, and almost 2 feet of clearance at the ends!!
I mean, who has that kind of room!!?!
Furthermore it says to mount on non-combustable surfaces only. Everyone I see out there mounts their camper electrical stuff onto plywood -- is this a problem?
So, RB50 & EB50 owners -- did you also squeeze in your house electrical system under the seat there? If so, how did it go? If not, where else did you put this stuff? It's not obvious to me. I'm putting the 230Ah LiFePO4 battery under the seat, too, on the other side of my centered 15-gallon water tank, and I suppose I could put some of the electrical stuff there too, but anything I add there is decreasing my general purpose storage.
Furthermore, I could add some kind of extra cooling fan down there under the seat to keep the air moving.
- Where do you put your house electrical system?
- Are you worried about overheating / fire?
