Hi, MGM Metalworks, Where did you get the Fuel Tank, how much, did it come with pump, pipes, fuel door, wiring, fuel guage, or from another source? please help?
Cheers Doug
The tank is from the E-series cutaway/cab chassis models. The heavy duty 16ga steel tanks are up to 2008. After 2008 they went to a cheap stamped version, not worth messing with. Titan and MTS make cross-linked polyethylene replacement tanks. I've used both and they're both nice tanks.
The tank straps are available through a company called Liland
https://www.ebay.com/itm/Fuel-Tank-...=item5b3d5d2d47:g:vXkAAOSwcMhbnS0a:rk:33:pf:0
https://www.ebay.com/itm/Fuel-Tank-...=item5b3d5d2d33:g:Y1sAAOSwxSZbnqIB:rk:34:pf:0
The diesel sending units are pretty basic. The correct sending unit for the '08 and earlier tanks is: Motorcraft PS-191. They are however outrageously over-priced IMO. The sending units for gas models are way cheaper and can be made to work (diesels don't need the pump inside the tank...same fuel level sensor though)
The wiring is straight forward...I just make an extension harness with the right connectors on it and it's plug in and go. Fuel lines can be extended with some adapter fittings to go from hard line to AN style. Then we use fuel hose with push lock AN style fittings. AN adapters at the sending unit too.
Then the mounting cross members. I've done many of these tank installs. The first ones were with the cross members that were salvaged from the motorhome/box truck chassis that we got the tanks from. These parts will fit but they're a pain to get in the frame, drill the appropriate holes, etc...
I'm now on the 2nd revision of my own cross members and they work much easier. Put them up in the frame, adjust things until its all square, clamp in place, drill some holes, bolts, tighten, done.
I made a special set of 'dimple dies' to create a recessed opening for the factory fuel door. Then we take the factory fuel door bracing and inner sheetmetal and fit it in the van behind the rear AC. You're left with a fuel filler opening that looks exactly like the original. No welding required...just the stomach to drill a 4 5/8" hole in the side of your van with a pretty tight tolerance of where it must go in order for all of the pieces to fit up right... haha
The paint can't handle the shrinking and stretching going on so it flakes off after pressing the recess
Another van just after paint
The fuel fill can also be routed into the wheel well area. I just like the factory look so I went through the trouble of making the dies and doing all the extra work.
