Rear swing arm storage box $275
boywonder
So Cal
Rear swingarm storage box $275 Used but fully functional.
Local pickup only in So Cal (Orange County)
Includes the two metal jerry cans (rotopax not included)
Rotopax or traction boards fit nicely in side pocket
There are also holes in the rear panel for a rotopax mount.
I like that box! and offered at a great price...I'd be on your doorstep boywonder if I wasn't on the other Coast.
It would be easy to rejuvenate the box without having to re-powder coat. Aluminess uses Rust-Oleum Canyon Black spray paint to match their powder coat for touch-ups...can hardly tell the difference. In this case, I'd just spray the whole thing.
https://www.amazon.com/Rust-Oleum-2...,+rustoleum+spray+paint&qid=1712683506&sr=8-3
Couple of questions:
1. How do you remove the jerry cans? Can you fit 2 or 3 of them?
2. Top box is water resistant, yeah?
3. Do you have storage area dimensions by chance?
You rotate the cans 90 degrees (*along their vertical axis ;)) to get them out......so only room for 2.
It does not have a seal around the lip where the door closes, but one could be added....the rest of the box is sealed.
The large open area is 24"W x 15"D x 19"H
If I got my hands on that box, it would go to my local fab shop and have them cut-off the panel that sits in front of the fuel can storage & reattach with a piano hinge on the bottom (just like the one above it), I'd also add 'hinged latching safety padlock Hasp's' on the left & right side to secure the 'gate' (protecting the 3 scepter runts I'd store inside).
@boywonder, does that mount on one of the Aluminess hinge pin/bumper swing out arms? Or, did you fab something else?
I had it mounted to an Aluminess swing arm, but it can be mounted to pretty much any swing arm.....
