Drkstar32
Advanced Member
- Joined
- Mar 4, 2017
- Posts
- 79
2006 E350 6.0/ Fairly uneducated in automotive.
Two issues.
I have been having trouble with my vacuum pump. The original OEM pump died in Jan 2002. Replaced and it lasted until 3 weeks ago. Took it to EIS in Sherwood OR and that one lasted 10 minutes of driving. They replaced it and that one lasted two days. This time check engine light and battery light came on as well as losing power steering. Replaced again and I picked it up yesterday 10/7/22. Crossing my fingers. The same thing was happening to all the new ones including the first replacement in Jan. A round metal thing is being knocked off. I guess there is a piston in the pump and it is knocking it out somehow. So says my mechanic. So I got it from the mechanic on his first try 3 weeks ago. He also did a computer EGR delete. I was in a hurry and just gave him my card, got my receipt and went on my way. Well I noticed a charge for an SCT X4 which I found boxed up in the back of the van. I had no idea what it was. I called and asked and he said it was needed for the delete and tune. Fine. I figured it would be good to be able to see accurate reads for the gauges. Yesterday when driving home from vacuum pump #4 install, my dash temp gauge almost topped out. This morning I did some quick reading on the SCT. I plugged it in and went for a drive. I have no idea what it means other than the coolant temp and EOT. Reading on this forum it seems the safe average readings are around ECT190-205 and EOT a few degrees higher. I have included a pic of my SCT display. Is this reading dangerous to my engine? At 246 I pulled over and shut her down. Got her home and it is parked. I feel that if I would have continued driving it would have climbed. Outdoor temp was about 86 degrees and it was regular driving with about 10 minutes on the freeway. I would pay someone to teach me how to take advantage of this piece of equipment. Thanks for reading and I appreciate any input. This van is my home for a large part of the year.
Two issues.
